110V (?) - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
User Tag List
post #1 of 6 Old 06-28-2014, 03:55 PM Thread Starter
7upstang's Avatar
Quoted: 8 Post(s)
110V (?)
The 110v A/C (I think that's what it's called) in the back seat of my truck won't hold a plug. The power works fine, the socket itself is loose. Everything falls out, I have to hold a plug in the socket for anything to work.
Is there either a way to tighten the socket up or has anyone replaced one? How difficult is the process?
2011: F-350, King Ranch. It will remain stock.
90: Mustang- Full Bolt-ons
2011: Mustang...made 957rwhp
7upstang is offline
post #2 of 6 Old 06-28-2014, 04:29 PM
Quoted: 30 Post(s)
Not sure if any adjustment. I highly doubt there is. I suspect you will have to replace it.
Even thought this thread is not about the power plug, it does show how to access the area the plug is located...hope it helps.
Secondary USB in Armrest Center Console - Diesel Forum - TheDieselStop.com
Larry1013 is offline
post #3 of 6 Old 06-28-2014, 06:02 PM Thread Starter
7upstang's Avatar
Quoted: 8 Post(s)
Thank you sir, that will help a lot.
7upstang is offline
post #4 of 6 Old 06-28-2014, 06:41 PM
I replaced mine, I think it was around $10. Holds fine now.
HCFR34 is offline
post #5 of 6 Old 06-28-2014, 11:16 PM Thread Starter
7upstang's Avatar
Quoted: 8 Post(s)
Oh thank goodness, I figured the part would $60 at least from ford.
7upstang is offline
post #6 of 6 Old 06-29-2014, 02:58 AM
I checked my credit card statement and found a charge from my Ford Dealer for $8.54. I get a 10% discount. Easy to replace, had two tabs on each side. Just sort of worked it out with a small screwdriver.
Now the serpentine belt we replaced at 100k, it was around $120.00, may be a little more, from the dealership.
Had to just replace the water pump at 105k, the aftermarket warranty covered $600 of the total $700 replacement cost.
HCFR34 is offline
