CB mounting locations - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
post #1 of 6 Old 05-21-2014, 09:50 AM Thread Starter
A fine bad example
Tidestroke6.7's Avatar
Wanting to install a Galaxy 959 and linear. I am looking at modding the inside of the console or mounting to the passenger side of the console. The linear will likely go in the secret compartment if I can ventilate it sufficiently.
Anyone have pics of an install?
2012 350 Lariat - Gone
Companion 5th wheel, SCT 5015, PIP Street tune w/SCT EGR pyrometer kit, Flo-Pro 4" exhaust w/ a 51" Donaldson muffler, No Limit CCV kit, H&S cold side Intercooler pipe kit, H&S secondary fuel filter kit (with Wix filter) are For Sale. PM if you are interested. Augusta,GA
Tidestroke6.7 is offline
post #2 of 6 Old 05-21-2014, 03:23 PM
tcreek's Avatar
I mounted one to the passenger side of the console.
2014 F350 DRW Kodak Brown Platinum 6.7 PSD
2009 Mustang GT Convertible Candy Apple 4.6
2001 F250 Supercab Bright Amber V10
tcreek is offline
post #3 of 6 Old 05-22-2014, 04:05 AM Thread Starter
A fine bad example
Same sized chassis and it fits.
Did you use an Upfitter switch? I am thinking of using one rather than string wire to the battery. Where'd you ground?
post #4 of 6 Old 05-22-2014, 06:37 AM
tcreek's Avatar
Since I had to pull the console to run cables (camera and radio), I hooked power to the 12 volt outlet in the console. It is live all the time, so have to make sure to turn the radio off when not using.
tcreek is offline
post #5 of 6 Old 06-27-2014, 11:02 AM Thread Starter
A fine bad example
I am installing sometime in October. I am going to mount the radio inside the console and get power from upfitter switch #3 (10a). I want to run all wiring through a hidden hole out under the cubby hole or out the side by the seat belt anchor. Since the linear needs airflow, I'll likely place the linear in front of the HVAC outlet under one of the front seats, so I can also switch it on/off. Then out to the bed with a coax for the antenna.
I'll hard wire the linear to the battery (+ & -), with an inline 50a fuse at the battery.
I'll take pics.
Last edited by Tidestroke6.7; 10-07-2014 at 05:16 PM. Reason: Initially said I'd install tomorrow. It happened 102 days later
post #6 of 6 Old 10-07-2014, 05:12 PM Thread Starter
A fine bad example
Got it done! Pics in a couple days as I forgot the USB cable for the camera at work. I decided against installing the linear; didn't know they are illegal in the 11 meter band.
I took pictures of the console taken part, the backrest removal process, and running the coax cable out the cab vent and into the bed through the rubber plug.
