Upgrade Base Model F-550 - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
post #1 of 5 Old 05-12-2014, 05:09 PM Thread Starter
Hey guys so for my mechanic rig I ended up w/ a BASE model F550... I was pretty choked when I showed up on site and that was what they had got me (Came from a fully loaded Dodge which I loved till I changed companies)
So anyways I found a bunch of other pickups on site that I can rob parts off of to upgrade my truck such as upgrading the head unit to the style that has a CD player, Aux in etc.
Now when I mean base, I mean base My truck has no cruise control, no CD player, nothing, just power windows, locks.
Anyways I changed over the deck today along with the nicer grey bezel but upon installing into my truck I discovered the harness coming out of the deck going to the Aux Line input was not there and is tied in with the main harness on the old truck. So short of peeling my harness apart and switching it over what can I do.
also where is the Mic so I can remove it and xfer it over to my truck.
Now that the stereo system is out of the way, I also plan on stealing the fog lights off of the other truck but I haven't had a chance to see if the harness is tucked up there so does anyone know? I am aware that I do have to change over the headlight switch which is no biggy.
Thanks guys.
Keep in mind this is NOT the NAV radio I'm installing, just the mid-range head unit that has the chrome on the knobs and CD player/AUX
j-rousseau is offline
post #2 of 5 Old 05-24-2014, 01:27 PM
travisH3's Avatar
Feedback Score: 13 reviews
is it an XL or XLT? XLT has the wiring for the fogs, you just need the fogs and the wiring harness that goes from fog lights to plug on the driver side headlight. and then the switch. XL the wiring isnt there i dont believe. our 2015 XL f450 isnt here yet so i cant go and check
T-rav
2010 F350 6.4- H&S Single turbo kit, 5" flo pro,No limit SS cold side kit, No Limit intake, MPD billet CCV/oil filler, newton leveling kit, RED Newton traction bars, custom projector retrofit in oem lights and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 5 Old 12-13-2014, 09:54 AM
The kit from ford is $300 but it comes with new fuse panel that you don't even need. I don't know why they include this with the kit. My truck is an XL so I don't know if that makes a difference. FYI new headlight switch included.
The harness for fog lights is mounted on front of truck, but the kit includes a harness from center of truck to individual fog lights.
2011 CCLB DRW 4X4 bone stock, but not for long
ande6009 is offline
post #4 of 5 Old 12-13-2014, 10:07 AM
acjet88's Avatar
Quoted: 31 Post(s)
Garage
I would suggest getting a factory service manual from www.helminc.com. It has all the wiring diagrams in it and would give you an idea of what to look for or if need be what to install. Only cost me $180 and its well worth it IMO. Has all kinds of info in It.
Edit: forgot to mention that it has 3D diagrams to help you locate certain parts.
2012 Ford F-250 Lariat CCSB Fx4 Off-Road
6.7L Powerstroke Turbodiesel
EGR/DPF/DEF Delete
5" Flo-pro Straight Pipe
SCT x4 w/ Innovation Diesel Tunes
Edge Insight CTS2
No Limit EGR Delete
ReadyLift SST Stage 3 2.5F/3R
Fuel Savage 20x9 Wheels
Goodyear Duratracs 325/60/20
Uniden 980SSB CB Radio
60" Firestik II Antenna
50-Gal Transfer Flow Trax II Auxiliary Tank
acjet88 is offline
post #5 of 5 Old 12-13-2014, 11:33 AM
Ill check on that website
I pulled out the old meter and found the blue wire was low beam and the purple wire is high beam.
ande6009 is offline
