13 upfitter switches, can you power when truck is off? - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
User Tag List
post #1 of 4 Old 04-28-2014, 03:11 PM Thread Starter
12 upfitter switches, can you power when truck is off?
i have strobes id like to run when the truck is off. can you power the switches to work with the truck off?
Grassman is offline
post #2 of 4 Old 04-28-2014, 03:41 PM
ZMANN's Avatar
Quoted: 494 Post(s)
I will post while we wait to see if someone with a 13 has done it
but for discussion sake to keep you entertained in the meantime LOL
I was contemplating the same for a different reason
the previous years they were Key on activated only also and even go off when starting
however I am sure you could supply one or all switches with constant power
if the 13 has a fuse box for each switch like mine does you would pull the fuse so it does not back feed and run a fused wire to the supply side of the fuse prong that you removed
there are probably a few ways to accomplish this
06 KR 4x4 BPD remote OEM Oil cooler /EGR cooler/water pump6 phase FICM , ARP studs,
Rize 4 link Toyo 37" camper modified special
For a truly terrible firearm experience I suggest Taurus
ZMANN is online now
post #3 of 4 Old 04-28-2014, 03:50 PM Thread Starter
Typo...I have a '12 I edited the first post
Grassman is offline
post #4 of 4 Old 05-17-2014, 08:25 AM
barobbin's Avatar
Quoted: 3 Post(s)
using the stock up fitter setup, no. and what zmann said is true for the 11 and up trucks also
barobbin is offline
