2013 f250 upfitter switch install - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
User Tag List
post #1 of 12 Old 03-23-2014, 03:11 PM Thread Starter
I have a 2013 f250 platinum and am trying to install upfitter switches. Can't seem to find plug in dash for the switch cluster. Anyone know if ford did or didn't wire platinums for this option already? Can't believe they wouldn't put this in a truck that has every other option.
JohnHenry is offline
post #2 of 12 Old 03-23-2014, 03:52 PM
Just did this the other day. Take out that little cubby beneath the 12v plug too. Makes it much easier.
http://www.ford-trucks.com/forums/at...6&d=1343733122
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
The Following User Says Thank You to rustyshakelford For This Useful Post:
hobiekaw (09-18-2015)
post #3 of 12 Old 03-23-2014, 04:33 PM
El_Tee's Avatar
The harness with the plug that runs underneath the A/C controls comes with the relay kit. It's not back there from the factory. If that's what you're asking.
2012 F-250 XLT 4x4 - H&S tuned - Sinister EGR delete - Flo-Pro 5" downpipe back - Method "Mesh" 18x9 - Toyo M/T 35x12.50 - more to come..
El_Tee is offline
post #4 of 12 Old 03-23-2014, 05:17 PM Thread Starter
I see the plug for the brake controller but the plug for the switches wasn't part of it. The harness on sale on ebay looks like it has the brake controller in it as well. Thought I wasn't finding the plug because it was tucked back.
post #5 of 12 Old 03-23-2014, 05:26 PM
El_Tee's Avatar
If all you have is the switches and it didn't come with any type of wiring or the relay box, you'll need to buy that as well. There is no harness for the switches behind the center of the dash. I'll try to find the P/N of just the wiring assembly, it doesn't come with a harness for the TBC.
El_Tee is offline
The Following User Says Thank You to El_Tee For This Useful Post:
JohnHenry (03-23-2014)
post #6 of 12 Old 03-23-2014, 09:08 PM
andys08's Avatar
I was looking for this info all day lol. Did you get the parts from ford? Price and part numbers please
2004 6.0 6spd,475hp southbend clutch,sct livewire custom tunes done by brians truck shop,5in straight, leveling kit ,egr delete,traction bars,arp studs. (Sold)
2011 6.7 lariat ccsb tinted,air bags with daystar craddle,Titan fuel tank, mini max with custom mount,5th wheel hitch,hids,icon 4.5in lift in front and dealers full leafs in rear,2wd valence,stock lights pulled apart and painted, all other lights tinted,
andys08 is offline
post #7 of 12 Old 03-23-2014, 09:14 PM
El_Tee's Avatar
The Ford P/N is BC3Z-14A303-B.
I bought mine from my local stealership but paid way too much for it.
$80.55 shipped on eBay.
New Upfitter Switch Jumper Wire Harness 2011 2013 Ford F250 F350 F450 F550 | eBay
If you feel more comfortable buying from ford, just copy and paste the part number on http://www.fordparts.com
El_Tee is offline
JohnHenry (03-24-2014)
post #8 of 12 Old 03-24-2014, 05:41 PM
andys08's Avatar
Just left the dealer he said it's wired in from 2008 to current is this true. The switches are $112
andys08 is offline
post #9 of 12 Old 03-24-2014, 05:47 PM
El_Tee's Avatar
I can assure you that my truck absolutley was not wired behind the dash. The only harness that is already in place is behind the headlight knob. You'll plug the relay box that you have to buy into that harness. There is then another harness that runs off the relay box that YOU route behind the dash to plug the switches into. Have your dealer show you where its wired if he's so confident.
El_Tee is offline
post #10 of 12 Old 03-24-2014, 07:39 PM
andys08's Avatar
I didn't think it was just wanted to double check before I buy it
andys08 is offline
