Replace Factory Sub - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
User Tag List
post #1 of 14 Old 01-17-2014, 10:45 PM Thread Starter
Long Member
TMAG6.0's Avatar
Replace Factory Sub
Im looking to replace the factory sub in my 2014 but the wiring harness plugs directly into the sub box. Im thinking the factory amp is inside the box too, that may be a problem. Anyone done this without cutting the factory harness? Is there a way to "piggyback" my new sub with the factory one?
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click HERE to save a childs life.
TMAG6.0 is offline
post #2 of 14 Old 01-18-2014, 06:00 AM
scummins's Avatar
I remember reading a couple people had tried this and were not happy with the result for the time and money.
11 Lariat
6" lift, 37's, Moto Metals, H&S, SPE, JL SPL2K
scummins is offline
post #3 of 14 Old 01-18-2014, 11:49 AM
MorganM's Avatar
I added poly fill to the stock box and noticed a reasonable improvement. Reasonable for a few bucks and minimal time investment.
MorganM is offline
post #4 of 14 Old 01-18-2014, 02:41 PM
Hoverp's Avatar
Can you please explain in detail what you did?
Thanks!
2014 F350 CC Short bed, Fully loaded, Platinum Edition. 6.7L Scorpion Tuxedo Black. 3.55 ELD, FX4, Sup heater, 5th package , BFG Radial All Terrain: icon_ford:
Hoverp is offline
post #5 of 14 Old 01-18-2014, 03:54 PM Thread Starter
Long Member
TMAG6.0's Avatar
Good idea. I was considering taking the box apart and exploring anyway. Maybe reusing the stock box and somehow replacing the speaker, or transferring the stock guts into my box.
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
TMAG6.0 is offline
post #6 of 14 Old 01-19-2014, 07:44 AM
MorganM's Avatar
Thanks!
Sure.
I removed the subwoofer box from the truck, and seperated the speaker from the box. Then, I borrowed a bag of poly-fill from my wife, similar to this. I inserted about 1/3 to 1/2 of the contents into the box around and behind the speaker, and re-installed everything in reverse as I removed it.
I'm in no way an automotive audio expert, but folks in that space have been doing this for years to make a box "seem bigger". If you Google polyfill and subwoofer, you'll find numerous hits explaining the physics behind the effect.
More power and a better speaker, this does not trump. Though for a minimal time investment and very little cash, it's a reasonable upgrade, imo. I would say I can feel the bass slightly more. You may be able to play with the amount of stuffing to have a more, or less, dramatic affect- good luck!
If you try it, please tell us what you think!
MorganM is offline
post #7 of 14 Old 01-19-2014, 07:52 AM
MorganM's Avatar
For a modest upgrade, I intend to try this
JL box JL box
with a tiny amp running off the stock wiring. Everything I've read indicates the OEM box is too thin/ weak to have an appreciable impact with any speaker or power level beyond stock.
The JL microsub is suppused to fit where the stock sub lives, but I've not confirmed these measurements myself.
MorganM is offline
post #8 of 14 Old 01-19-2014, 08:39 AM
Hoverp's Avatar
Sure.
Thanks! Good stuff!
Hoverp is offline
post #9 of 14 Old 01-20-2014, 10:51 PM Thread Starter
Long Member
TMAG6.0's Avatar
For a modest upgrade, I intend to try this JL box with a tiny amp running off the stock wiring. Everything I've read indicates the OEM box is too thin/ weak to have an appreciable impact with any speaker or power level beyond stock.
That looks exactly like the one I have. Actually have two + amp I pulled from the previous truck....Next opportunity I'll try taking plugs and such off stock box to make the JL work without cutting wires.
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
TMAG6.0 is offline
post #10 of 14 Old 01-20-2014, 10:52 PM Thread Starter
Long Member
TMAG6.0's Avatar
Sure.
Did you have to take out the rear seat to get the sub out?
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
TMAG6.0 is offline
