Factory Remote Start Location - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
User Tag List
post #1 of 6 Old 01-15-2014, 11:31 AM Thread Starter
I have a 2011 F250 KR. I'm trying to find the install location for the factory remote start. Any ideas?
castellscl is offline
post #2 of 6 Old 01-15-2014, 03:35 PM
El_Tee's Avatar
It should be above the glovebox door, plugged into the TPS module. Take the side panel off the passenger side of the dash, and the module is right under the air duct.
2012 F-250 XLT 4x4 - H&S tuned - Sinister EGR delete - Flo-Pro 5" downpipe back - Method "Mesh" 18x9 - Toyo M/T 35x12.50 - more to come..
El_Tee is offline
post #3 of 6 Old 01-15-2014, 07:25 PM
I am looking at buying one ans installing my self, El Tee do you know how difficult it is to install?
Hazzard is offline
post #4 of 6 Old 01-15-2014, 09:48 PM
You can install it yourself but the dealer needs to enable it using IDS. Plus you will need the keys cut and programmed.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #5 of 6 Old 01-16-2014, 03:43 AM
El_Tee's Avatar
X2. The antenna takes less than 5 minutes to install, it consists of two zip ties, and plugging a jumper into the TPS module. However, like WildStyle said, the dealer will need to enable the remote start in IDS.
El_Tee is offline
post #6 of 6 Old 01-16-2014, 05:17 AM Thread Starter
So what about the ford security system if I already have the factory remote start? Is that an easy one?
