7 way trailer plug center pin? - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
post #1 of 17 Old 01-13-2014, 12:01 PM Thread Starter
Bryce18's Avatar
Quoted: 17 Post(s)
I am installing 2 flood light bars on my rear bumper. I am wiring them to an aux switch, but I also am planning on wiring them to come on with my back up/ reverse lights.
I figured the easiest way to tap into the reverse lights would be the 7 way trailer plug (center pin wire) instead of searching for the correct taillight wire.
Can anyone confirm that the center pin in the trailer plug is for backup lights?
I turned my key to on position and placed truck in reverse and used a tester but had no power on center pin.
Am I missing something?
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #2 of 17 Old 01-13-2014, 12:03 PM
dannanw's Avatar
Quoted: 48 Post(s)
Garage
not sure from ford, but the industry standard is thats for batt + on a trailer (like a camper or any trailer with a batt)
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 17 Old 01-13-2014, 12:34 PM
lug
lug's Avatar
Your Ford's center or auxillary pin (Purple wire) is for reverse lights. Check the fuse panel for missing or inop fuse. Ford uses fuses for the trailer side so even if your reverse lights on the truck work doesn't mean the RV jack does. On some boat trailers the center pin activates the reverse hydraulic brake lockout so you can back up the trailer.
lug is offline
post #4 of 17 Old 01-13-2014, 12:34 PM
Corey@CNCFAB's Avatar
Quoted: 549 Post(s)
Yep. IIRC trailers do not have back up lights.
If anything RedTrailers.com is a very good site for that kind of stuff and the old man that owns the business is extremely helpful.
E99CCLB 450/400s,STG1cam, KC38R, 4" exh,CNC FAB fuel&oil lines,140vIDM,BTS,S&B
97 ECLB F250 4x4 stock
96 CCLB F350 4x4 stock
EDGE,S&B,SCT,PHP Hydra,TS-Perf,OEM parts,Sam Wyse trans,VB's,LED's,MBRP,ISSPRO,ICON,FOX,KC TURBOs,SD 7.3 fuel kits, HPOP lines
www.cncfab.us or email sales@cncfab.us
Corey@CNCFAB is offline
post #5 of 17 Old 01-13-2014, 12:43 PM Thread Starter
Bryce18's Avatar
Quoted: 17 Post(s)
This is the diagram right on the plug
Top: RH turn/brake
Bottom: LH turn/ brake
Top right: marking/ running lights
Bottom right: ( + )
Top left: ( - )
bottom Left: trailer brakes
Center pin: backup lights.
I'm guessing the bottom right (+) is for 12v accessory ( trailer battery)
And the top left (-) would be ground
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #6 of 17 Old 01-13-2014, 12:47 PM Thread Starter
Bryce18's Avatar
Quoted: 17 Post(s)
I have power on all pins except center. And I'm stumped as of why.
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #7 of 17 Old 01-13-2014, 12:49 PM
Quoted: 549 Post(s)
Thats strange. I guess use a meter to double check.
This is industry standard.
http://www.redtrailers.com/WiringInfo.asp
post #8 of 17 Old 01-13-2014, 01:00 PM Thread Starter
Bryce18's Avatar
Quoted: 17 Post(s)
Even on that diagram they claim center is backup lights.
Well I guess that plan isn't going to work. I guess I will have to find a wire going to one of my taillights.
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #9 of 17 Old 01-13-2014, 01:12 PM
Quoted: 549 Post(s)
Do u have a multimeter? Put ur truck in R and see if you have 12v at that center pin when ur truck b/u lights come on.
post #10 of 17 Old 01-13-2014, 01:21 PM
lug
lug's Avatar
Have you confirmed fuse #70, 10A, in the Power Distribution box is operational?
lug is offline
