fog lights replaced need to move to upfitter - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
post #1 of 3 Old 01-12-2014, 12:18 PM Thread Starter
TXGold's Avatar
I put some new 40watt lights I got from Plashlights.com in place of the fog lights. I want to power them with the same harness. I would have just installed new switches but plashlights forgot to mention there wasn't a harness, or I should have asked, one of the two.
How do I rewire the fog light harness to be powered with the upfitter switch?
Or am I over thinking this and you can control fog lights with headlight switch(knob)?
Ryan
2014 Ram 2500 MC Limited Black/Black, 295/65R20 Toyo AT2Ext's, Thuren 2.5 Springs, Fox/Thuren 2.0 ITP Shocks
TXGold is offline
post #2 of 3 Old 01-12-2014, 03:59 PM Thread Starter
TXGold's Avatar
Never mind. The fog lights, for those that have factory lights and don't know this cause you can't tell if they are on or off, are operated by pulling the headlight knob out. No need to use up fitter switches when replacing factory "fog lights" with after market lights.
TXGold is offline
post #3 of 3 Old 01-12-2014, 07:47 PM
Unless you want the high beams and the fogs, or now driving lights, on at the same time. The fogs turn off when the high beams are turned on. An upfitter switch may still be a better option.
Cheers,
2013 F350 Lariat CC LB 4x4 6.7
Diamondback HD tonneau cover modified to carry 3 dirtbikes and 1 quad.
xplormor is offline
