Mytouch problems - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
User Tag List
post #1 of 13 Old 10-19-2013, 10:20 AM Thread Starter
Bullitt1289's Avatar
Mytouch problems
Has anyone else had issues with this thing? My wife took the truck yesterday and the radio stopped working and will not work at all now. The screen is working fine but no music will play no matter what you select. Turn the volume knob and nothing happens. Power button does nothing as well as all of the preset buttons and the tune knob.
I went into settings and did a master reset and it did nothing. Anyone have any ideas? Maintenance dept. at the local dealership is closed already for the day so I'm stuck until Monday. Only thing I else I can think of would be disconnect the batteries for a a while and see if it somehow resets itself.
Sent from AutoGuide.com App
13 F250 FX4 CC Lariat Blue jean metallic
01 Mustang Bullitt #1289
02 F250 XLT 7.3 (sold)
SSgt USAF
Bullitt1289 is offline
post #2 of 13 Old 10-19-2013, 10:48 AM
<b>Premium Member</b>
BigGreen06's Avatar
Quoted: 52 Post(s)
That's what I was going to say, disconnect the Batteries. I had a simillar issue with my 10, even though they are different units, same problem, screen and nav still worked, but no music, and I was only half way through my trip, so luckily it was in the morning on a weekday, the dealer told me to disconnect the batts for 30 mins and thn reconnect them. Did it, and it worked, got my Sirius back and my iPod functions.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen; www.oslights.com
BigGreen06 is offline
post #3 of 13 Old 10-19-2013, 11:32 AM
Quoted: 18 Post(s)
I had this same problem yesterday with my 2013 Lariat with the MFT and navigation. I spoke with the 1-800 SYNC help line and they walked me through the reset. After doing this several times, the radio portion would still not work. The help line mentioned that a Sirius update happened yesterday and that they had multiple calls with the same problem. After I got home, I disconnected the batteries and turned the headlights on to drain the electronics. After 1 hour, I reconnected the batteries and the radio functions were restored. After doing this, I spoke with a local dealer and they said that they would have done the same as part of their diagnostics. After inputting all of my preferred settings, it was back to normal. Hope this helps.
Sterling6.7 is offline
post #4 of 13 Old 10-19-2013, 04:41 PM Thread Starter
Thanks guys. I disconnected the batteries before left, went out for a ride on the bike, and I'll reconnect them when I get back. Hopefully the problem will be fixed.
SSgt USAF
post #5 of 13 Old 10-21-2013, 08:19 AM Thread Starter
Reconnected the batteries and everything seems to be working fine now. Had that stupid wrench light pop on the first time I drove it after but it turned itself off.
SSgt USAF
post #6 of 13 Old 10-23-2013, 03:34 AM
Quoted: 2 Post(s)
I feel for you all. I had a Taurus sho that Ford did a buy back on because the system was such a disaster. It is a shame that Ford cannot get it working right even now. That is what they get going with Microsoft. Not that Dodge is great but there system is, I believe, unix based and is quick and responsive. Ford needs to get that system straight and fast. It it has been three years now. I found the only way for connected media to work well is to stream Bluetooth. Though my nav system would constantly freeze up. The prior generation system with the large screen was the best OEM nav system I ever used.
2016 Ford F-350 King Ranch 4x4 Super Crew 8 Foot bed. 2014 F-150 Super Crew 6.5 Foot bed 4x4 Platinum.
MisterScott is offline
post #7 of 13 Old 10-23-2013, 11:12 AM
Quoted: 9 Post(s)
I had this exact same radio problem right as I was leaving on an 8 hour road trip!!! A reset didn't fix the problem but, upon further research, rather than disconnecting the battery, I pulled the fuse for Sync with the truck running, turned the truck off, put the fuse back in, then started the truck. Sync restarted and the radio worked.
I can't remember the fuse number, but it's in the manual. The fuse box is on the passenger side foot well, by your right foot.
Drewtk is offline
post #8 of 13 Old 10-27-2013, 05:34 AM
ATCguy's Avatar
Driving back home from Louisiana this weekend, my Sirius radio did the same thing 2 or 3 times. The screen was still on, the station was displayed, as well as the song being played. But no sound, and I could not change stations.
So I reached over and touched the FM tab... and the system switched to FM radio. I touched the Sirius tab again, and the system switched back to Sirius radio, which now played just fine. I had full control again.
Like I said... it did this 2 or 3 times on me. Usually after stopping for gas or something, and restarting the vehicle... and once, while driving along, right in the middle of a song the system just cut out. I did the same as above (FM tab, Sirius tab) and all was normal again.
Tom
2014 F-450 PLATINUM
2014 Dutchmen Voltage 3200 5th Wheel Toy Hauler
2007 Honda GL1800A Gold Wing
ATCguy is offline
post #9 of 13 Old 10-29-2013, 03:53 PM Thread Starter
When mine screwed up nothing would play. I could switch between the different inputs but no music on anything.
SSgt USAF
post #10 of 13 Old 10-29-2013, 04:12 PM
BigGreen06's Avatar
Quoted: 52 Post(s)
Dang, you guys are scaring the crap out of me with all these stories of the my touch system not functioning properly. I just got word that my 2014 just arrived, and I was all excited, but now I'm a bit freaked out, that $h!t aint gonna work.
Accufab Elbow
LineX in the Bed
