speaker thump/noise over bumps - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
post #1 of 4 Old 10-01-2013, 05:01 PM Thread Starter
TXGold's Avatar
Any idea where to begin troubleshooting this. It sounds like it is coming from the back speakers, maybe sub?? Before I had this problem and it was from front speaker/speakers?? Not sure where to look or how to pull the headunit out and check connections.
If anyone has had a similar problem I'd appreciate hearing about how you solved your issue.
2014 Ram 2500 MC Limited Black/Black, 295/65R20 Toyo AT2Ext's, Thuren 2.5 Springs, Fox/Thuren 2.0 ITP Shocks
TXGold is offline
post #2 of 4 Old 10-01-2013, 05:56 PM
Hellobatman's Avatar
My sub makes a blurping noise kinda... Like a popping on a few hd stations. Dk if it's similar to yours but i haven't figured it out yet. Didn't do it before.
2013 F-250 Lariat FX4, 6.7 Scorpion, All the bells and whistles!
Hellobatman is offline
post #3 of 4 Old 10-01-2013, 06:37 PM Thread Starter
TXGold's Avatar
It sounds like when you touch the plug on a guitar cable before you plug it in, if that helps.
TXGold is offline
post #4 of 4 Old 10-15-2013, 06:28 PM Thread Starter
TXGold's Avatar
Took the stereo surround off and pulled the stereo out and checked connections were secure and put everything back. Nothing looked loose except the XM antenna came loose so I put it back in place. Now I have more popping. It sounds like maybe a ground is loose. Any idea where the ground would be for the metal frame that the stereo mounts too? Could this be an internal problem with the stereo? I hate to drop my car off for warranty work and be without a truck for a week.
TXGold is offline
