Anyone have a Samsung Galaxy S3 synced? Text mess? - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
post #1 of 8 Old 06-19-2013, 10:10 AM Thread Starter
Dealer synced my S3 and I recived a text no problem.. then it quit. I deleted the phone and reinstlled it.. got first text message ok...then nothing... any ideas?
2013 F350 CC KR SRW. Ruby Red/ Tan trim
Loaded!
SOLD
99 F250 EXt cab 7.3 Lariet. 170,00...no issues!
JMCFAN is offline
post #2 of 8 Old 06-19-2013, 10:25 AM
I can't get mine to read text at all. Subscribed.
For Sale: 2013 Lariat Ultimate CCSB 15K miles
3.55 ELD, Tinted, AMP setps, Retrax Pro, Two Spot Rigid D2 Dually's, Two Flood Rigid D2 Dually's, Fabtech 6in lift, Billstein struts, Dual Pro Comp Steering Stabilizers, 20in XD Addicts, 37x13.5x20 Toyo M/T, Line-X, Diversi-Tech 12" drop hitch, H&S Mini Maxx, 5in Flo Pro, H&S EGR delete, S&B CAI
FMKeith is offline
post #3 of 8 Old 06-19-2013, 11:20 AM
I also have an S3 and wasted a couple of hours messing around with this. What I saw was I can receive, and reply to, text messages as long as the truck is sitting still (or probably less than 3 mph). Once you're moving reply seems to be disabled. IF I try to use voice commands I get the "phone not compatible" message which is BS since it will work standing still. The owners manual mentions an advanced menu under the phone settings, that seems to have disappeared, that dealt with text message configuration (MAP Profile). From what I've been able to find on the net, this function was broken with the Sync update late last year. FWIW it works the same in my wives explorer. If anyone knows how to get to the MAP Profile menu I would be interested to here how its done.
John
2013 F-250 6.7L 4x4 Lariat CCSB - Stock for now...
Action H53 is offline
post #4 of 8 Old 06-19-2013, 11:41 AM Thread Starter
Ah... both of the texts I was abel to recive I was standing still.... odd...
Loaded!
SOLD
JMCFAN is offline
post #5 of 8 Old 06-19-2013, 03:41 PM
Coincidentally my wife sent me a text on the way home from work. I should clarify what I'm getting in the truck. While driving when I get a text I get the information box pop up, and if I'm quick enough, I can hit listen and hear the message. If I try to use voice commands I get the "your phone doesn't support" message. Either way, you can't reply while moving. If you want to prove that the reply function is disabled while moving, pull up the message screen under the phone menu while stopped. Staying on that screen start driving and you will see the reply and view (I think) options grey out. All of this is not a big deal except it bugs me that A) Sync says that my phone doesn't support messaging when it obviously does, and B) if they encourage you to use the phone "hands free", why can't you reply to a text in the same manner?
JMCFAN - sorry if I'm rambling on, the only thing I know that may help is make sure you say yes to all the questions when pairing up your phone. I'd be very interested to know if anyone has had better luck with the S3.
John
post #6 of 8 Old 06-19-2013, 08:42 PM
This is actually a setting in the Bluetooth profile on your Android OS. I had to turn off BT, enable setting, then delete the pairing and re-pair to get the new BT profile to register with Sync.
I get the same "your phone doesn't support" BS as well trying to do the voice thing to read the message. Very annoying.
Also... (kinda related) at some point when trying to pair it went into some weird loop were it wouldn't complete the pair process. I ended up needing to do the factory reset on the myTouch to get it to work again. Since then it's been fine. Takes a LONG time to reset but oddly didn't even lose my station presets.
HTH,
Sean
srteague is offline
post #7 of 8 Old 06-20-2013, 04:31 AM
Thanks Sean! I'll give it a try when I get off work tonight.
John
post #8 of 8 Old 06-21-2013, 05:47 PM
Lococoin's Avatar
Send a message via MSN to Lococoin
What year of trucks are you talking about? I have an s3 hooked up to my navigation in my 2012 and it will show a message but won't say who it is from. Does yours show who its from?
By reply do u mean an actual reply or the generic ones that are pre programmed in the nav? Mine only shows the generic replies.
Lococoin is offline
