Add Dash buttons? Next to traction control - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
User Tag List
post #1 of 10 Old 06-17-2013, 05:48 AM Thread Starter
It is possible to get buttons for either side of the traction control button? It appears that there is room for two additional buttons in this location - just above the 4x4 selection.
dparksfl is offline
post #2 of 10 Old 06-17-2013, 05:57 AM
There are factory options that go there so yes you can get the buttons to go there. They will have the option printed on the button though.
2012 F250- 4.5in. lift, 24x12 rockstar II's painted tuxedo black, 37x13.50x24 M16's, KEM race tunes, 5in. exhaust, and much more.
DillonC is offline
post #3 of 10 Old 06-17-2013, 08:09 PM Thread Starter
Any ideas on what those options are? In all the exploded diagrams, nothing shows the buttons on the left side on the panel.
Maybe if I know what those options are, I'll be able to find the part.
dparksfl is offline
post #4 of 10 Old 06-17-2013, 08:17 PM
Well I know the one on the left is the hill decent control that comes with the fx4s, but I can't remember the other one.
DillonC is offline
post #5 of 10 Old 06-18-2013, 04:22 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
I think it is the passenger airbag shut off switch.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 10 Old 06-18-2013, 05:03 AM
Airbag light, not switch. The switch for airbag is a key lock under the steering column by your right knee Add Dash buttons? Next to traction control-1371556989965.jpg
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #7 of 10 Old 06-18-2013, 05:10 AM
jcain is offline
post #8 of 10 Old 06-22-2013, 12:16 AM
Anyone know if u can add down hill assent by just putting in a button ?
Dankdave79 is offline
post #9 of 10 Old 06-22-2013, 05:56 AM
I would imagine you could but you would have to get it activated at a dealership.
DillonC is offline
post #10 of 10 Old 07-16-2013, 07:41 AM Thread Starter
Originally Posted by jcain View Post
Airbag light, not switch. The switch for airbag is a key lock under the steering column by your right knee Attachment 126626
I think the dash may have changed a bit on the 2013's. My traction control button is to the left of the radio. It's flanked by two blanks. I was hoping to get a momentary contact added to one of those sides.
To the right of my radio is just a Sync advertisement placard.
-David
dparksfl is offline
