Amp Research Power Step Wiring Help - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
post #1 of 5 Old 06-02-2013, 11:00 AM Thread Starter
TX_TRU_STUD's Avatar
Quoted: 44 Post(s)
Hey guys,
I got my passenger side front and passenger side rear to operate the steps on that side, but I can not get the drive side to work. I can get the driver side rear to work but its janky.
Can anyone post pix of their wire config so I can see what you put those 2 wires to?
Yes I have read the manual and will be calling the monday.
TX_TRU_STUD is offline
post #2 of 5 Old 06-02-2013, 11:03 AM Thread Starter
Quoted: 44 Post(s)
2013 F250 by the way...
I have about 6 lime green/purple wires FYI.
I do not have an OHM meter or know how it works. I assume you touch it to the wire and open the door and you get some readout? Otherwise it's at 0....?
post #3 of 5 Old 06-02-2013, 12:56 PM Thread Starter
Quoted: 44 Post(s)
Figured it out. There are like 6 lime green/purple wires in the weave. The dark green from AMP goes to the lime green solid color.
The dark green/purple AMP goes to one of the lime green/purples, you just have to try each one till it works.
post #4 of 5 Old 06-02-2013, 10:11 PM
Yep you got it, mine had the same # of green/purple and I had to ohm each one as well.
Swampfox is offline
post #5 of 5 Old 06-03-2013, 05:52 AM
Somehow I got lucky and found the 4 wires for mine on the first try. I did walk away and read a little bit to get a couple of pointers. First, match the wires from the steps to the wires in the bundle, and more importantly, the wire size for the 4 door wires are all the same. The other green/purple wires I found were all a little bigger than the one I was looking for from the door. At least in my bundle, once I found the first door wire, the other ones seemed to be close together in the bundle.
I checked mine for resistance (ohm) to ground. They were grounded (some resistance showing on the multimeter) when closed and open circuit (no reading) when the door was open.
novi408 is offline
