Having trouble with the NAV on my new 2013 - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
User Tag List
post #1 of 28 Old 05-14-2013, 05:53 AM Thread Starter
Summitman's Avatar
I have a new 2013 F350(435 miles) with the My Ford Touch. The NAV system is about a 2 city streets off. When I'm driving on the highway, somethimes it had NO idea where I am or sometimes it shows mw driving off to the side the road.
2013 F350 Crew/Short
Gray on Black
Amp boards
20" XD Addicts/325-65-20 GY Dura Trac
Retrax Cover
BDS Leaveling kit with Fox Shocks
NAV
Fab 4 Front Pre-Runner Bumper
T-Rex Grill
Summitman is offline
post #2 of 28 Old 05-17-2013, 07:16 PM
I know this is no help but mine does the same damn thing. I need to take it in and see what the hell is wrong with it.
FMKeith is offline
post #3 of 28 Old 05-19-2013, 09:43 AM Thread Starter
Summitman's Avatar
My service manager plugged into the truck and found a newer nav update. I'm trying hat for now. At times it's better, other times its horrible. Hopefully it comes out of it.
Gray on Black
Amp boards
Retrax Cover
NAV
T-Rex Grill
post #4 of 28 Old 05-21-2013, 06:31 PM
I took mine in today. They said that this is now a known problem with the 2013's. They have some update that is supposed to fix it.
For Sale: 2013 Lariat Ultimate CCSB 15K miles
3.55 ELD, Tinted, AMP setps, Retrax Pro, Two Spot Rigid D2 Dually's, Two Flood Rigid D2 Dually's, Fabtech 6in lift, Billstein struts, Dual Pro Comp Steering Stabilizers, 20in XD Addicts, 37x13.5x20 Toyo M/T, Line-X, Diversi-Tech 12" drop hitch, H&S Mini Maxx, 5in Flo Pro, H&S EGR delete, S&B CAI
FMKeith is offline
post #5 of 28 Old 05-22-2013, 06:36 AM Thread Starter
Summitman's Avatar
I had mine updates to the newest version on the 18th, but it didnt fix it.
Gray on Black
Amp boards
Retrax Cover
NAV
T-Rex Grill
post #6 of 28 Old 05-23-2013, 05:50 AM
TampaSteve's Avatar
Feedback Score: 3 reviews
Doing it now, it's an APIM update, then reconfigure the Navagation module.
2012 F-250 6.7 CCSB
Spartan war hammer, wicked wheel II, S&B intake, 4" flow pro w/dual mufflers, rigid dually's, IPad in dash, JL stealth box under rear seat, Hertz HSK 165 front and rear, JL 450/4, 500/1, line x, roll x tonneau, Titan Tank, and coming soon 6" lift, American force 22x11 Recon SS wrapped in 37's.
TampaSteve is offline
post #7 of 28 Old 05-23-2013, 05:57 AM
My truck is at Ford right this second getting updated. I will let you guys know how it goes.
FMKeith is offline
post #8 of 28 Old 05-23-2013, 10:06 AM
TampaSteve's Avatar
Tire Size is the issue
The Navigation system uses a combination of inputs to accurately locate the vehicle in all conditions. The input from the GPS satellites is the primary input; however the system also looks at the wheel pulse from the ABS module to calculate distance along with the gyro information from the RCM to calculate direction. This allows the system to continue to function in conditions where there may be a loss in signal (such as in a tunnel).
Altering tire size affects the count of the wheel pulse because the system will calculate distance inaccurately - for example the system expects 100 yards based on the count, but the vehicle actually traveled 110 yards because of the larger tires. When viewed on a map, this will place the vehicle off the road or contribute to a mis-timing of corners.
2012 F-250 6.7 CCSB
post #9 of 28 Old 05-23-2013, 10:17 AM
Thank you. I have a Hypertech unit on its way. So, I am guessing that will fix this problem.
FMKeith is offline
post #10 of 28 Old 05-29-2013, 12:50 PM Thread Starter
Summitman's Avatar
I just spoke to Jimmy at Hypertech. He was aware of the problem, and said the speedo cal unit they sell wont fix the problem. I'm trying to talk to Ford to see if they have a fix for it.
Gray on Black
Amp boards
Retrax Cover
NAV
T-Rex Grill
