How Long Can I Run the Ice Chest? - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
post #1 of 4 Old 04-18-2013, 07:57 PM Thread Starter
Need an electrical wizard out there.
I have a 12V refridgerator which draws .96 Ah/hr at expected ambient tempuratures.
Assuming the (duel) batteries in my 2013 F250 are healthy and the outside tempurature is around 75F how long should I be able to safely run the fridge before being able to start the 6.7 scorpion would become questionable?
There is about a 20 foot always-hot line (don't know guage but with a 15amp fuse) running from the battery to the 12V receptical in the back of the camper.
Can anyone help me? Thanks in advance.
2013 F-250 Lariat
JSolve is offline
post #2 of 4 Old 04-18-2013, 10:22 PM
JSchuricht's Avatar
There are a lot of variables in that that you didn't mention. What you need to know is the ah capacity of your batteries, multiply by 2 because you have 2 batteries. Using a Diehard platinum as a example, you have 75 ah x2 at 20 hours which means you can draw 150 amps for 20 hours before they are dead. Now this assumes that the batteries are fully charged, new and the temperature is fairly normal. Now you need to figure out the required minimum power to get the truck to crank and replicate the exact same conditions, ie. no vent running, no lights on, same amount of time to crank, etc. Subtract this amount of power from the 150 ah c/20 rate and you will be in the ballpark.
Basically .96 ah would take 156.25 hours to kill the batteries by itself. Typically you don't want to go below 50% to avoid a premature battery failure, less if it's a starting battery. Let's say 80% soc to be safe so 150 ah x .2 / .96 would be 31.25 hours. But don't forget the truck's normal draw when off, typically >.05a but not sure on the 6.7 so 150 ah x .2 / (.96+.05) is 29.7 hours. To play it safe, you could move for a 90% soc which would be 150 ah x .1 /(.96+.05) which would be 14.85 hours. I would use a 15% correction factor for unknown condition of batteries and draw so 14.85 x .85 is 12.6 hours.
On the other hand you could just disconnect one battery so you know you have one good one to help start the truck. It's not a good long term solution but wouldn't hurt if you just did it a few times.
JSchuricht is offline
post #3 of 4 Old 04-19-2013, 04:30 AM
Lf83's Avatar
Quoted: 3 Post(s)
^^^^???? What he said. Lol
leveled 2011 F250
Fox 2.0 Shox
35x12.50x20 Toyo AT II's
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #4 of 4 Old 04-19-2013, 09:40 PM Thread Starter
Thanks JSchuricht - I'll limit use to 8 hours on battery power to be on the safe side.
2013 F-250 Lariat
JSolve is offline
