Keypad Code - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
User Tag List
post #1 of 12 Old 04-05-2013, 11:39 AM Thread Starter
Keypad Code
Does anybody know how to find the keyless entry keypad code without going to the dealer? The code used to be located on the module back in the day. I bought my truck used and it didn't come with the card in the owners manual with the code on it.
mjz52 is offline
post #2 of 12 Old 04-06-2013, 12:20 PM
I'm 99% sure its in the ecm, not in the vehicle due to thiefs . Dealer should be able to pull it for around $30.00
GhostRyder71 is offline
post #3 of 12 Old 04-06-2013, 12:22 PM
michaelbyoung's Avatar
Mine was way up under the dash behind the radio on some box. I had to move some insulation out of the way to see it with a flashlight. Mines an 06 though.
Sent from AutoGuide.com App
2006 F-350 Lariat Crew Cab Long Bed 6.0 Diesel
Chrome Pkg All Stock 185,000 miles
B&W Turnover Gooseneck w/ 5th wheel companion
ScanguageII High idle mod On board air
2011 Jumpseat Gutted Cat Mikeymod muffler
EGR delete CCV mod EC1 coolant Zoodad mod
2000 F-250 Lariat Crew Cab Short Bed 7.3 Diesel ***STOLEN*** 11/19/2011
4" Rancho Lift
215,000 miles
afe intake
4"turbo-back
IAH delete
Foil Delete
michaelbyoung is offline
post #4 of 12 Old 04-08-2013, 06:48 AM Thread Starter
Sounds like I had better take it in, thank you...
mjz52 is offline
post #5 of 12 Old 04-08-2013, 07:05 PM
I found my code near the fuse box located on the passenger side under the dash on the right side. I removed the cover and the code was right there.
KyStrokin'14 is offline
post #6 of 12 Old 04-08-2013, 07:35 PM
BIG Laing's Avatar
My code was on a card in the owners manuel packet...
BIG Laing is offline
post #7 of 12 Old 04-08-2013, 08:56 PM
It's under the dash on a box of some sort. Just do some searching and you'll find it
blacknight is offline
post #8 of 12 Old 04-09-2013, 09:58 AM Thread Starter
Sweet! Found it there. Thanks guys!!
mjz52 is offline
post #9 of 12 Old 03-02-2014, 11:17 AM
purduefarmboy460's Avatar
Send a message via AIM to purduefarmboy460
Good Info
I didn't have the card in my manual for the entry code. Found it as described! Thanks for the posts!
purduefarmboy460 is offline
post #10 of 12 Old 03-22-2015, 02:44 PM
mhelm's Avatar
Open glove box, when you unhook glove box, bottom right corner, 5 digit code on a control module.
mhelm is offline
The Following 2 Users Say Thank You to mhelm For This Useful Post:
cdrracing (05-26-2015), RuHunting (05-10-2015)
