Installing sub, Need some help - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
Old 02-06-2013, 07:17 AM
I have ordered a new sub and box for my 2012. I need some help determining where to get my subwoofer audio signal from. I have read that some have intercepted and used the signal from the factory sub and that it may already be low level so no preamp converter would be needed. is this correct? Does anyone know which wire colors are positive and negative? Thanks in advance.
Old 02-06-2013, 10:10 AM
Does this sound correct?
Blue w/ red stripe - "always hot" connection from the BCM
Violet w/ red stripe - enable/clip detect
Violet w/ green stripe - SW+
Green w/ white stripe - SW-
2012 F250 subwoofer wiring question - Ford Truck Enthusiasts Forums
Old 02-09-2013, 09:09 AM
I couldn't get the sub wiring to work for me on my 2011 superduty, even tho it worked on my 2011 f-150. On the superduty, I had to tie in the LOC at the headunit to the front left and right speaker feeds.
Old 02-09-2013, 09:21 AM
why didn't u use the rear speaker wires ?
that seem better for balance
Old 02-09-2013, 09:26 AM
2011 is all i could find on the 12volt.com 2011 f250 super duty diesel
Old 02-10-2013, 08:30 AM
Yep, ended up just using the right rear speakers. Turned out great. Thank guys.
BTW, the JL Audio stealthbox is awesome. I have had louder systems before but with limited space this was the way to go. Also, they now offer the 13.5 inch sub in a 2 ohm. I ordered it off Ebay for $749, free shipping and no sales tax.
Old 02-16-2013, 06:10 AM
Can you post some pictures?
Sent from AutoGuide.com App
Old 02-18-2013, 11:29 PM
Another way to get a signal is to obtain it from the factory sub speaker wires using the OEM amp and wiring the two sets in parallel so they don't over load the OEM amp. The OEM speaker is a dual voice coil speaker thus has two sets of outputs from the OEM amp. Soundoffaudio.com has all kinds of sub options and adapters for the Ford SD. I ordered a rear seat sub with two 8" a Kicker amp, wiring, adapters for $600. All I have to do is remove the rear seat and install it and put the rear seat back. I also replaced the rear speakers and the front speakers as well as the front tweets in the "A" pillar with surface mount tweets.
