Whine Sound Every Minute Or So - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
post #1 of 12 Old 08-01-2012, 03:52 AM Thread Starter
HoboCoastie's Avatar
Question Whine Sound Every Minute Or So
The title pretty much says it all, but when the engine is off there's a short whine sound that comes from under the truck about once every minute. It lasts about a half second and sounds kind of like the fuel pump.
Is this normal?
HoboCoastie is offline
post #2 of 12 Old 08-01-2012, 06:57 AM
BIGGDADDYT's Avatar
It could be the turbo mine does it for sec when warming up then stops.
2012 F-350
Dually
FX4
Black on Black
Line-X Bedliner
BIGGDADDYT is offline
post #3 of 12 Old 08-01-2012, 04:36 PM Thread Starter
No, this is when the engine is off. Keys out sitting at the curb.
I was looking under the truck for damage because I hit a piece of steel on the highway that fell off some jack wagon's truck.
No damage except it pulled the wires out of the deutsch plug that lights my passenger side running board, but that's when I heard the whine.
post #4 of 12 Old 08-01-2012, 05:32 PM
BIGGDADDYT's Avatar
Does it do it every time?
Sent from my Autoguide iPad app
2012 F-350
Dually
FX4
Black on Black
Line-X Bedliner
post #5 of 12 Old 08-01-2012, 07:08 PM
My 2012 does that also. It sounds like a pump either fuel or urea, at least hat is what I have assumed. Great question that I would like an answer to.
Sent from my iPad using Autoguide
Huff250 is offline
post #6 of 12 Old 08-02-2012, 03:00 AM Thread Starter
The guy at Ford told me when I bought a jug of DEF, that I should rinse out the nozzle when I'm done as the fluid will crystallize. I wonder if the sound isn't some type of circulatory pump for the DEF?
post #7 of 12 Old 08-02-2012, 08:11 AM
vlxjim's Avatar
It sounds like it could be the Waste gate control solenoid. It makes a motor type sound 30-60 sec. after key off. Have the dealers tech call the Ford hotline. I told my dealer what it was the tech was like I'll be the judge here. He was on hold with the hotline when he came out to hear the noise. He did not know but I did and a few minutes later the hotline tech comes on and the dealer tech hardly got his words out and was told to replace the Waste gate control solenoid. Its a quick fix.
2011 F250 PowerStroke CCSB Lariat FX4 Loaded | Icon 2.5" Stage 2 | Icon track bar | Top Gun Dual Stabilizers | 20" Fuel Boost wheels +1 offset | 325-60-20 Hankook Dynapro ATm | RBP RX3 steps | BakFlip F1 Bed Cover | All Sales Mfg Fuel Door | Randy Ellis Light Bar | Hella Lights | aFe Magnum FLOW Pro-GUARD 7 Air Filter |
vlxjim is offline
post #8 of 12 Old 08-11-2012, 02:17 PM
My best bet would be the DEF pump.
Ben_Garrett is offline
post #9 of 12 Old 08-12-2012, 12:34 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
Is this normal?
Is it a whine or does it sound more like a computer beep???
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #10 of 12 Old 08-12-2012, 06:48 AM Thread Starter
It's a whine. I know it's a little cross-culture, but if you've ever heard the fuel pump on a modern Harley right before you start it, it sounds just like that, but about half as loud.
