| 6.7 Electronics Discussion 6.7 Electronics Discussion |
Remove Door Panels 2012 F350
I didn't find a thread specifically explaining this so I figured I'd ask... Anyone?
Fairly easy. Depends on which side you want to get off. If you're doing the drivers side you need to slide a small screw driver under the mirror and seat control panel to pry it up and disconnect it. Do the same to the window controls. The whole section disconnects and you can take the cables off. Then in the top of the upper compartment, just under the arm rest there's another little panel. Pop it off and take the screw out. Lastly, just run your fingers around the sides and bottom of the panel pulling out. If you start at the bottom corner it's easiest. You'll pull out and the trees will pop out of the door. Once you have the whole panel loose, pull out on the bottom and lift up clearing the door lock.
Awesome, got it... Thanks!
now i know what to do. thanks mate for the info. i was also researching for guides and i ended up on this thread. cheers! anyway guys i just found out something good that might help others who are looking for ford door panels
I was hoping this title would help since its blatantly obvious.... Glad it helped! I still haven't done the rears yet.
I Have a 2011 F350 and just took my panels off. There are no tree style clips on mine. The panels have down facing hooks that go into notches in the doors. So to get mine off I just took out the 2 8mm bolts under the armrest hidden behind the little cover panel plus 2 8mm bolts that are exposed on the very bottom. Then just simply lift up to clear the manual lock lever and pull them back and reach in and unplug the switches and remove the panel.
Oh forgot to add you need to remove the tweeter panels that are at the corner of the window first . They have 2 metal push clips , so just pull straight back on them and they will pop off.
Thanks! Much appreciated!
