| 6.7 Electronics Discussion 6.7 Electronics Discussion |
Side mirror replacement lamp
I have a 2011 F250 and need help replacing the side mirror lamp. Does anyone know how to remove the yellow plastic cover?
Motor the mirror up and insert a flathead screwdriver at the base of the mirror. Gently place it in and there is a tab you push and it will pop out. Use a light if needed. It tajes a few seconds.
Thank you
Awesome, Thanks!
No problem. I thought the same when I put the Recon LED's on. It turns out it is pretty simple. Very little force needed.
anyone know what bulb it takes?
