Adding Amps to Factory Nav - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
Old 08-10-2011, 05:59 PM
I have the factory NAV unit. I would like to add a 4 channel amp to drive the factory door speakers, and a mono amp to drive a JL sub.
What I am looking for is a wiring harness that plugs inline with the factory harness (I assume at the factory amps) that would easily allow me to wire to a LC6i, as well as the speaker leads back to the factory wiring so I don't have to run new wires into each door.
My 4 channel is an older amp, but has always sounded great - but not a ton of power, so I don't think using the factory speaker wires will be an issue.
I can/could tap into the factory wires, but would prefer to use a pre-made harness to make life easy if one is available.
Any suggestions, and/or wiring photos are appreciated.
Old 08-10-2011, 07:43 PM
I am not sure anything like this exists. I have done a ton of research on factory integration and have not seen anything remotely like it. If you do find something, be sure to post it.
Old 08-11-2011, 08:29 AM
I never found one when searching either. Certainly would have made the install easier.
Old 08-11-2011, 09:10 AM
I haven't looked lately but Crutchfield usually has adapters to go to factory wiring for the stereos.
Old 08-11-2011, 01:31 PM
Send a message via AIM to Dim Sum
Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
I was looking at this? Maybe this will help you?
Old 08-13-2011, 11:27 AM
I looked at that one, but it doesn't list the 2011s in the application list.
I will contact Pac-Audio and see what they say.
