wiring diagram for the factory sub/amp? - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion 6.7 Electronics Discussion
post #1 of 7 Old 08-09-2011, 06:06 AM Thread Starter
matty21's Avatar
does anyone have this? im wondering which colour is which to hook up to an aftermarket amp inputs.
thanks guys,
Mat
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
http://www.facebook.com/video/video....91500544216050
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #2 of 7 Old 08-09-2011, 04:39 PM
grmreaper's Avatar
Here is the best one i have found, I used it too hook up my JL Clean Sweep
2011 Ford F250 DirectWire 2.0 Vehicle Information
Item Wire Color Polarity Wire Location
12 Volts red (125A) + battery or BCM, black 1 pin plug (G), pin 1
The BCM (Body Control Module) is the fuse box in the passenger kick.
Second 12 Volts green/red or blue/red (15A) + ignition switch, 7 pin plug, pin 4
Starter blue/white + ignition switch, 7 pin plug, pin 7
Second Starter N/A
Ignition white/orange + ignition switch, 7 pin plug, pin 1
Second Ignition N/A
Third Ignition N/A
Accessory purple/green + ignition switch, 7 pin plug, pin 6
Second Accessory N/A
Third Accessory N/A
Keysense blue/gray + ignition switch, 7 pin plug, pin 5
Data Bus yellow/orange (TX), purple/gray (RX) data PATS Transceiver, black 4 pin plug, pins 3 and 4
The PATS (Passive Anti-Theft System) Transceiver is around the ignition switch. The PATS ignition wire is purple/orange in pin 1, and ground wire is black/gray or black/yellow in pin 2.
Can Bus High gray/orange (medium speed CAN) data data link connector, black 16 pin plug, pin 3
Can Bus Low purple/orange (medium speed CAN) data data link connector, black 16 pin plug, pin 11
Can Bus Sw N/A
Power Lock blue/green - driver kick or BCM, black 26 pin plug (C), pin 6
Power Unlock yellow/purple - driver kick or BCM, black 26 pin plug (C), pin 8
Lock Motor gray/brown 5 wire driver kick or BCM, 32 pin plug (D), pin 26
Driver Unlock Motor blue/green 5 wire driver kick or BCM, 32 pin plug (D), pin 21
Passenger Unlock Motor purple/gray 5 wire passenger kick or BCM, 32 pin plug (D), pin 31
Parking Lights (-) yellow/orange - headlight switch, gray 10 pin plug, pin 2
May need to interrupt the headlight switch ground wire when triggering this wire. It is black/gray or black/yellow at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information.
Parking Lights (+) yellow/blue + BCM, 10 pin plug (E), pin 6
Hazards brown/yellow - BCM, black 52 pin plug (B), pin 32
Turn Signal (Left) blue/green (F); gray/brown (R) + BCM, green 26 pin plug (F), pin 8; 32 pin plug (D), pin 12
Turn Signal (Right) yellow/purple (F); purple/orange (R) + BCM, green 26 pin plug (F), pin 7; 32 pin plug (D), pin 15
Headlight yellow/blue - headlight switch, gray 10 pin plug, pin 7
AutoLights purple/green (interrupt to turn off autolights) - headlight switch, gray 10 pin plug, pin 4
Reverse Light blue/white + BCM, 32 pin plug (D), pin 13
Left Front Door Trigger green/purple - N.C. passenger kick or BCM, black 26 pin plug (C), pin 9
Right Front Door Trigger white - N.C. passenger kick or BCM, black 26 pin plg (C), pin 5
Left Rear Door Trigger green - N.C. passenger kick or BCM, blk 26 pin plug (C), pin 20
Right Rear Door Trigger yellow - N.C. passenger kick or BCM, blk 26 pin plug (C), pin 21
Dome Supervision gray/purple (dome lamp); purple (puddle lamp) + BCM, 12 pin plug (A), pin 1; black 26 pin plug (C), pin 1
Trunk/Hatch Pin N/A
Rear Glass Pin N/A
Hood Pin blue/orange - N.C. BCM, green 26 pin plug (F), pin 2
Trunk/Hatch Release N/A
Trunk Release Motor N/A
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock Transponder, ignition, and accessory
See Tech Doc 1098 for wiring information.
Trunk Alarm Shunt N/A
Tachometer blue ac Customer Access Harness
The Customer Access Harness is above the driver kick, taped to a wiring harness. On vehicles without the Customer Access Harness, go to any fuel injector and use the wire that is not blue (gasoline), or use the camshaft position sensor, which is white/green at the PCM, middle, black 98 pin plug, pin 32 (diesel). The PCM (Powertrain Control Module) is on the passenger side of the engine.
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal black (in), blue/orange or purple/blue (out) - N.O. clutch switch, gray 6 pin plug, pins 2 and 1
Fuel Pump yellow/purple (gasoline) - BCM, green 26 pin plug (F), pin 6
The BCM (Body Control Module) is the fuse box in the passenger kick. On diesel models, use brown/white (+) at the Inertia Fuel Shutoff Switch above the passenger kick, gray 3 pin plug, pin 1.
Rear Defroster white/orange - latched HVAC Module, gray 32 pin plug, pin 25
Mirror Defroster same as rear defroster
Left Front Heated Seat (CAN bus)
Right Front Heated Seat (CAN bus)
Speed Sense purple/orange ac Customer Access Harness
Brake Wire purple/white + brake switch or BCM, black 52 pin plug (B), pin 28
Parking Brake white/purple - Customer Access Harness
Horn Trigger purple/green - horn switch or BCM, black 52 pin plug (B), pin 33
Wipers (LIN bus)
Left Front Window (Up/Down) blue/gray - yellow/purple A master window switch, 8 pin plug, pins 5 and 1
Right Front Window (Up/Down) brown/yellow - green/orange A driver kick, door harness
Left Rear Window (Up/Down) blue/orange - yellow A driver kick, door harness
Right Rear Window (Up/Down) gray/purple - brown/green A driver kick, door harness
The power sliding rear window open/close wires are purple/brown - yellow/orange (5 wire) at the overhead console switch, 12 pin plug, pins 4 and 9.
Sun Roof (Open/Close) pur/brn - yel/org (function with ignition on only) - overhead console switch, 12 pin plug, pins 6 and 8
Sun Roof (Limit/Close) N/A
Memory Seat 1 purple/white - driver kick, door harness
Memory Seat 2 yellow - driver kick, door harness
Memory Seat 3 N/A
Radio 12V gray/red + radio, gray 24 pin plug, pin 1
Radio Ground black/blue or black - radio, gray 24 pin plug, pin 13
Radio Ignition gray/blue (except navigation) + radio, gray 24 pin plug, pin 2
Radio Illumination purple/gray (dimmer) + radio, gray 24 pin plug, pin 3
Factory Amp Turn-on purple/red (sub amp); brown (audio amp) + radio, gray 8 pin plug, pin 4; gray 24 pin plug, pin 7
Power Antenna N/A
Left Front Speaker (+/-) white - white/brown +,- radio, gray 24 pin plug, pins 8 and 21
If equipped, the audio amplifier is under the driver dash. On vehicles with amplifier, the speaker wires are white - white/brown at the audio amplifier, black 8 pin plug, pins 4 and 8.
Right Front Speaker (+/-) white/purple - white/orange +,- radio, gray 24 pin plug, pins 11 and 12
If equipped, the audio amplifier is under the driver dash. On vehicles with amplifier, the speaker wires are white/purple - white/orange at the audio amplifier, black 8 pin plug, pins 6 and 2.
Left Rear Speaker (+/-) white/green - brown/yellow +,- radio, gray 24 pin plug, pins 9 and 22
If equipped, the audio amplifier is under the driver dash. On vehicles with amplifier, the speaker wires are white/green - brown/yellow at the audio amplifier, black 8 pin plug, pins 7 and 3.
Right Rear Speaker (+/-) brown/white - brown/blue +,- radio, gray 24 pin plug, pins 10 and 23
If equipped, the audio amplifier is under the driver dash. On vehicles with amplifier, the speaker wires are brown/white - brown/blue at the audio amplifier, black 8 pin plug, pins 5 and 1.
Center Channel (+/-) N/A
Subwoofer (+/-) purple/green - green/white +,- radio, gray 8 pin plug, pins 1 and 2
Aux. Audio Input Left (+/-) blue - yellow/green (without SYNC) +,- radio, gray 16 pin plug, pins 7 and 8
Aux. Audio Input Right (+/-) blue/green - white/green (without SYNC) +,- radio, gray 16 pin plug, pins 6 and 14
RSE Video (+/-) white/green - brown/purple (rear camera video) +,- radio, gray 10 pin plug, pins 1 and 6
RSE Audio Left (+/-) grn/org - blu/brn or blu - gry/og (sat/SYNC audio) +,- radio, gray 16 pin plug, pins 1 and 2
RSE Audio Right (+/-) pur/brn-yel/blu or pur/grn-brn/wh (sat/SYNC audio) +,- radio, gray 16 pin plug, pins 9 and 10
Satellite Radio 12 Volts purple/red + Satellite Receiver, black 12 pin plug, pin 9
If equipped, the Satellite Receiver is under the driver dash.
Satellite Radio Ground black/blue or black - Satellite Receiver, black 12 pin plug, pin 3
Satellite Radio Ignition (CAN bus)
Satellite Radio Antenna (coaxial cable)
Satellite Audio Left (+/-) green/orange - blue/brown +,- Satellite Receiver, blk 12 pin plug, pins 5 and 11
Satellite Audio Right (+/-) purple/brown - yellow/blue +,- Satellite Receiver, blk 12 pin plug, pins 6 and 12
Item Size Depth Location
Headunit double DIN center of dash
Left Front Speaker 6 x 8 left front door
Left Front Tweeter left front door
Right Front Speaker 6 x 8 right front door
Right Front Tweeter right front door
Left Rear Speaker 6 x 8 left rear door or left rear pillar
Left Rear Tweeter left rear door
Right Rear Speaker 6 x 8 right rear door or right rear pillar
Right Rear Tweeter right rear door
Center Channel N/A
Subwoofer under or behind rear seat
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner (built into radio on some models) under driver dash
Smart Starter Kill Relay
Relay Type:
Part #:
OE Relay Part #:
n/a
n/a
n/a
Notes:
n/a
Alternate Part Notes:
n/a
Interface Modules
SKU Module Description Upgradeable Keys Required for Programming Keys Required for Operation
© 2007 Directed Electronics. All Rights Reserved.
DirectWire and its vehicle information are for the sole use of authorized Directed Electronics personnel and it's participating dealers and distributors. The information contained on these pages may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited.
2011 F350,CC,LB,Lariat,4x4,FX4,6.7L
2.5" Leveling kit - H&S Tuned and DPF bye bye
6k 55W Bi-xenon Morimoto Mini (H1) Projectors and HID fog lights
18x9 Fuel Hostage Black and Brushed wrapped with 325/65/R18's
JL audio 900/5 AMP, JL CleanSweep, JL 13TW5 sub
Waiting to be installed: EGR delete
On order: S&B intake - now 9 weeks and counting
grmreaper is offline
post #3 of 7 Old 08-09-2011, 06:46 PM Thread Starter
matty21's Avatar
do you have any pics of the wiring? on my 08 they just used the wires at the factory amp . then ran a power cable from the battery then a ground, but i dont know what they used for the acc. no RCA's or anything
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #4 of 7 Old 08-10-2011, 12:51 PM
grmreaper's Avatar
On my truck i have no NAV. So no stock speaker amp just the sub amp. I wired the remote wire for my cleansweep actually to my aux 3 upfitter. Its always on i run my HS and wired to 12v plug under the dash for my gps so its always on. I ran my amp remote off the cleansweep
The lack of rca's. Is why i used the cleansweep to feed my amp. I wired the cleansweep right behind the deck and spliced in there for my speaker inputs. Then rca?s from the cleansweep to my 900/5 amp
post #5 of 7 Old 08-10-2011, 01:29 PM
Dim Sum's Avatar
Send a message via AIM to Dim Sum
I was looking to just tap off of the stock sub/amp signal wiring, but if its too difficult, I'll just order the PAC adapter that plugs into the back of the HU.
-Steve
2011 F-350 Lariat 4x4 SuperCew: White Platinum Tri-Coat, Goodyear Wrangler Silent Armors, Window Tint
2001 Hyundai Elantra: Daily Driver
2007 Polaris Sportsman 700: Weekend fun!
Dim Sum is offline
post #6 of 7 Old 02-23-2015, 04:04 PM
barobbin's Avatar
Quoted: 3 Post(s)
did any one ever figure out the best way to tap into the stock system? I have an audio control lci2 and I was wondering what the best way was?
barobbin is offline
post #7 of 7 Old 02-23-2015, 04:56 PM
Quoted: 35 Post(s)
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Camper Package, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
