need help installing the UPFITTERS Switches - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 12 Old 07-04-2014, 10:40 AM Thread Starter
Guys,
I have read every single thread.. my problem is not the plug nor the wires. I can't get to mount the relay box for some reason. Does anybody have a picture how it got mount?
I can't seems to figure it out, I know it goes on the diver side close to the door but whre???
thanks!!!
Jose
DOGO X is offline
post #2 of 12 Old 07-04-2014, 11:18 AM Thread Starter
This is the only bracket I can see under the dash!! what I'm missing????/
DOGO X is offline
post #3 of 12 Old 07-04-2014, 11:20 AM Thread Starter
DOGO X is offline
post #4 of 12 Old 07-04-2014, 11:22 AM Thread Starter
Really Ford, you coul NOT include the two bolts!!!!!!!!!!!!!
DOGO X is offline
post #5 of 12 Old 07-04-2014, 12:16 PM
HighHP's Avatar
No I was pretty pissed about the missing bolts as well. I can't remember the size but I found a pack of 20 at Napa for like $5. I just brought the relay box to make sure I got the right bolts. Mounting that relay box is a major pain in the ***. Took me a good 45 mins to get the bolts threaded tight. One was ok but the other I could only use a Phillips in a 1/4" ratchet and get like a 1/16 turn at a time. If you can find the bolts with a hex head you will be much better off for the final tighten. Finding the plugs was ok but routing the final wiring into the center of the dash was stupid as well. Couldn't find the best path for the life of me and ended up with like 2"s of wire to play with behind the switches.
2013 - F350 CCLB. - 40" Lift on 40s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
The Following User Says Thank You to HighHP For This Useful Post:
DOGO X (07-04-2014)
post #6 of 12 Old 07-04-2014, 12:29 PM Thread Starter
Here is a picture of the famous plug for those who can't find it, before I remove it from the tap and after
DOGO X is offline
post #7 of 12 Old 07-04-2014, 04:23 PM
Banjo3's Avatar
I ran into this problem as well... I got tired of fooling with it and zip tied it to that bracket until I build enough patience to try it again
Banjo3 is offline
post #8 of 12 Old 07-04-2014, 07:41 PM
k7lvo's Avatar
If you place the relay box at about 45 degrees from horizontal and just below the vent so that the removable cover faces the removable panel I think you'll be able to see how it sets on the mounting bracket.
My problem is I can't figure out where the ground wire goes. I couldn't see anything that looked like the "IP frame fastener."
Lewis
2014 F-250 XLT CCSB 4X4
k7lvo is offline
post #9 of 12 Old 07-04-2014, 08:48 PM
HighHP's Avatar
I grounded mine to the relay frame bolts
HighHP is offline
post #10 of 12 Old 07-05-2014, 09:15 AM
Banjo3's Avatar
I grounded here, right side of throttle.
Banjo3 is offline
