Electrial Issues - Batteries/Dash go dead - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 4 Old 07-03-2014, 09:20 AM Thread Starter
I have 2004 Excursion with about 90,000 miles. Has run great. Recently started having what I thought was dead battery issue. Seemed like something was running batteries dead overnight. Couldn't find anything left on but battery voltage low. Replaced batteries. Problem continued with something running voltage low after sitting overnight. Need to charge for several hours before it will start. Now starting having problem with after running for couple minutes just stops for no reason and won't start until jump or charge batteries again. Have checked grounds etc. and all seems good. Now after getting started and running for several minutes sometimes the dash goes dead and all the gauges go to zero and radio lights go off, but heater/ac lights stay on. Then sometimes after several more minutes the heater/ac turns off and all electric goes dead, engine is running but fan off, windows won't operate etc. If I restart all sometimes seems to work well, or sometime doesn't work. Not consistent. Can't find any rhyme or reason to it all. I'm wondering if I have a major computer malfunction and worrying it will cost thousands to get fixed. Anyone else have similar experience or any ideas? Thanks
Sleeves is offline
post #2 of 4 Old 07-04-2014, 08:17 PM
El_Tee's Avatar
You may get a better response over in the 6.0 section.
2012 F-250 XLT 4x4 - H&S tuned - Sinister EGR delete - Flo-Pro 5" downpipe back - Method "Mesh" 18x9 - Toyo M/T 35x12.50 - more to come..
El_Tee is offline
post #3 of 4 Old 07-04-2014, 08:37 PM
Check ground wires to frame and fuse box and check wires for chaffing by PCM fender wall also make sure positive wire the small ones have good connection to battery
ebcc is offline
post #4 of 4 Old 07-07-2014, 07:49 AM Thread Starter
Great. I'll give it a try and let you know.
Sleeves is offline
