Navigation unable to pinpoint location - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 10 Old 06-21-2014, 05:47 PM Thread Starter
RTFU!
GridLine's Avatar
Quoted: 4 Post(s)
I own a 2014 f250. I picked my truck up from the shop on thursday june 19th with a new 4.5" lift and 37" tires. The shop is located about 85 miles from my house. To get home I plugged in my Address on the Nav and headed home and the nav system worked fine. 80 miles of the ride were highway miles.
Today was the first time I used the navigation since Thursday. I went to a buddies house about 25 miles away and traveled mostly on city roads. The navigation would start out accurate but with in a couple hundred feet would put my location off the road, basically in the wood line or lake paralleling the road I was on. As soon as the arrow would hit a side street it would recalculate the directions from the road it was on and send me in all different direction.
My question is, could the bigger wheels or lift throw off the accuracy of the navigation? I know the MPH is off by about 3-4mph but, i wouldn't think it would effect the nav like that. If it is, is there a way to fix this or should I take it to the dealership? Could it just be a faulty equipment issue. I just find it odd this is happening after i had the lift installed.
Any input is appreciated. Thanks.
2016 F350 KR
Thanks 8LUGTRUCKGEAR!
-Dave
GridLine is offline
post #2 of 10 Old 06-21-2014, 05:57 PM
IronCobra's Avatar
Quoted: 9 Post(s)
Well your nave is tied into your Speed Sensor. So yes, that could make for some pretty inaccurate readings
2016 F450 Platinum FX4 CC LWB
2016 Chaparral 360IBL Fifth Wheel: 15,500lbs
GONE - 2011 F250 FX4 6.7L Lariat Ultimate
IronCobra is offline
post #3 of 10 Old 06-21-2014, 06:00 PM Thread Starter
RTFU!
GridLine's Avatar
Quoted: 4 Post(s)
Is this normal? I haven't read anything on here about this happening before. Is there a fix for this? Thanks.
2016 F350 KR
-Dave
GridLine is offline
post #4 of 10 Old 06-21-2014, 06:20 PM
Have them perform TSB #14-0037. That fixed mine.
2014 F350CCSB 4x4 6.7L PSD
jsaund22 is offline
post #5 of 10 Old 06-21-2014, 08:23 PM
chodifer's Avatar
Use the search this has been covered. Unplug both batteries for ten to fifteen minutes and then reconnect. Problem solved
chodifer is offline
post #6 of 10 Old 06-22-2014, 06:17 AM Thread Starter
RTFU!
GridLine's Avatar
Quoted: 4 Post(s)
ok, great thanks.
2016 F350 KR
-Dave
GridLine is offline
post #7 of 10 Old 06-22-2014, 08:58 AM
The battery thing works for other years, but there is an actual TSB out on this issue for the '14 models. Here's a video from my YouTube channel describing it:
jsaund22 is offline
The Following User Says Thank You to jsaund22 For This Useful Post:
GridLine (06-22-2014)
post #8 of 10 Old 06-22-2014, 10:01 AM Thread Starter
RTFU!
GridLine's Avatar
Quoted: 4 Post(s)
jsaund22, I appreciate your help. I literally just came in from disconnecting my battery. I'll most likely take a ride to the dealer tomorrow. Thanks
2016 F350 KR
-Dave
GridLine is offline
post #9 of 10 Old 06-22-2014, 10:14 AM
No problem. If your issue looks like mine, the TSB will most likely fix it. I've used it quite a bit since the TSB and it works just fine. It was completely useless before.
jsaund22 is offline
post #10 of 10 Old 06-22-2014, 11:55 AM Thread Starter
RTFU!
GridLine's Avatar
Quoted: 4 Post(s)
so I unplugged the battery for about 20 minutes than went for a 20 mile drive to check out if that worked for these 2014. So far so good. The NAV tracked me perfectly. I drove on highways and side roads with no issues. Lets hope it stays that way.
If it starts acting up again I'll go with what jsaund22 suggested.
2016 F350 KR
-Dave
GridLine is offline
