wiring up a winch - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 7Likes
post #1 of 18 Old 06-19-2014, 08:56 AM Thread Starter
wiring up a winch
hey
I am installing new smittybuilt m1 bumpers on my 2013 crew cab this weekend and was wondering when wiring up my winch does it mater which battery I wire up to primary (passenger side) or secondary (Drivers side)
please advise
thanks
Deepsouthwood is offline
post #2 of 18 Old 06-19-2014, 09:05 AM
Quoted: 83 Post(s)
I doubt that it seriously matters when you consider a gasser only has one battery and many people have winches on them. Personally I would wire to primary battery on passenger side. I like the thought of it being closer to the output of the alternator.
chough1 likes this.
Larry1013 is offline
post #3 of 18 Old 06-19-2014, 09:20 AM Thread Starter
that's kind of what I was thinking the only thing in the owners manual was about if I needed to jump it off to use the primary battery
thanks
post #4 of 18 Old 06-19-2014, 09:21 AM
ZMANN's Avatar
Quoted: 1775 Post(s)
the batteries don't care
go to the easiest
they both are tied together and drain at the same rate
edit = interesting about the owners manual comment
We Miss you Ronnie
ZMANN is offline
post #5 of 18 Old 06-19-2014, 09:23 AM
Heavy_GD's Avatar
Quoted: 1648 Post(s)
Feedback Score: 3 reviews
I go to the battery that gets the feed from the alt, I also install a circuit breaker in the big line just in case.
ZMANN, El_Tee and Larry1013 like this.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #6 of 18 Old 06-19-2014, 09:25 AM
ZMANN's Avatar
agreed
I wouldn't contemplate running that size of a lead unprotected ( or any size wire for that matter )
We Miss you Ronnie
ZMANN is offline
post #7 of 18 Old 06-19-2014, 10:27 AM
IronCobra's Avatar
Quoted: 9 Post(s)
I had a 300 amp circuit breaker, but it seamed cheap and would trip under little pulling load. I installed a quick release welding coupler designed for 1-4awg cable. Works amazingly well.
Hot Max 23001 Welding Cable Cam Lock Connector for Size 4 to 1 AWG Cable
http://www.amazon.com/Hot-Max-23001-Welding-Connector/dp/B005TGLOXM/ref=sr_1_fkmr1_2?ie=UTF8&qid=1403202539&sr=8-2-fkmr1&keywords=Hot+Max+23001+Welding+Cable+Cam+Lock+Connector+for+Size+4+to+1+AWG+Cable+http%3A%2F%2Famzn.com%2FB005TGLOXM
2016 F450 Platinum FX4 CC LWB
2016 Chaparral 360IBL Fifth Wheel: 15,500lbs
GONE - 2011 F250 FX4 6.7L Lariat Ultimate
IronCobra is offline
post #8 of 18 Old 06-19-2014, 10:36 AM
Heavy_GD's Avatar
that works well, I use the ones at the stereo shops and usually leave them "open" until I need it.
if you need extreme duty go the marine route
GD
...because Patriot.
Heavy_GD is offline
post #9 of 18 Old 06-19-2014, 10:59 AM
IronCobra's Avatar
Quoted: 9 Post(s)
This is what I had. Not installed anymore though
http://www.amazon.com/300-Circuit-Breaker-Replace-12vdc/dp/B007AUPY6I/ref=sr_1_1?ie=UTF8&qid=1403204184&sr=8-1&keywords=300+amp+circuit+breaker
You really need something that can handle 350-400 amps for a 12k+ winch. That's why most serious winch users just go with a quick disconnect.
post #10 of 18 Old 06-19-2014, 11:01 AM
ZMANN's Avatar
I like those
haven't seen them used as a disconnect before
good idea
We Miss you Ronnie
ZMANN is offline
