2012 F250 Unable to disable reverse sensors - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 8 Old 06-12-2014, 03:03 PM Thread Starter
Quoted: 2 Post(s)
Hello,
When I set the reverse park aid to Off in the menu, the next time I start the truck is reverts to On. I have tried to turn it off about 10 times now and always keeps reverting back to On.
What am I doing wrong? I am doing this from the Settings menu and not when the indicator pops up when you put the truck in reverse.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #2 of 8 Old 06-12-2014, 03:22 PM
I_AM_RP3's Avatar
I don't think you as the consumer can permanently disable it. Because backup sensors are now mandatory by the gubment so turning them off is only temporary, like traction control. I'm pretty sure I read that somewhere, and soon rear view cameras will be mandatory too.
I_AM_RP3 is offline
post #3 of 8 Old 06-12-2014, 04:45 PM Thread Starter
Quoted: 2 Post(s)
Well why do they give you the option to Select No! that seems silly!
wreedPS is offline
post #4 of 8 Old 06-12-2014, 08:13 PM
Quoted: 2 Post(s)
So you can turn it off if the tailgate is down or you're pulling a trailer, for that drive cycle.
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
The Following User Says Thank You to jcain For This Useful Post:
texaslimeaide (06-13-2014)
post #5 of 8 Old 08-20-2014, 12:57 PM
Mine are not turning up on the screen to turn them off. Pretty annoying when backing up a trailer. Anybody experience this?
Reaper1 is offline
post #6 of 8 Old 08-20-2014, 09:38 PM
My back up sensor shuts off when I plug in a trailer, I am not sure how it is this way but it has been like that since I bought it
Hazzard is offline
post #7 of 8 Old 09-14-2014, 07:52 PM
Reaper you probably have the my key feature actIvated.
I believe the truck recognizes trailer brakes and that is when it will automatically disable them, when you pull a trailer with no brakes the sensors will alarm.
sleepersilverado is offline
post #8 of 8 Old 09-15-2014, 03:01 AM
Rattler1's Avatar
Quoted: 22 Post(s)
I recall reading somewhere on here that it has to do with whether you are using an administrator (?) key or a mykey when you change the setting. Hope that can get you pointed in the right direction.
Let us know what you come up with.
2015 F250 XLT crew cab long bed 4x4.
Rattler1 is offline
