amp install with stock wiring - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 5 Old 04-19-2014, 10:39 AM Thread Starter
cajun_driller's Avatar
installing a 150 watt amp and sub in a 2012 F250. Can I use the wiring from the stock amp for constant power and enable/clip or should I use all new wiring? I know I "should" use new wiring, but will the stock wiring work?
2012 Ford F-250 Lariat CC
SCT 3015 with Punch It Performance tunes. Carli BackCountry 2.0 - Deaver Leaf Springs - Carli HMS - 35"x12.50x20 ProComp Xtreme MT2 - Fold-a-Cover - 40 gal American Aux fuel tank - SCT Livewire TS - Kicker 8" ported sub - Phoenix Gold 150 watt amp.
cajun_driller is offline
post #2 of 5 Old 04-19-2014, 11:30 AM
dieseldesi's Avatar
Quoted: 4 Post(s)
You need to run a new power wire from the battery with fuse in it. I replied to your question on the my thread with more details.
2013 F250 CC FX4
dieseldesi is offline
post #3 of 5 Old 04-19-2014, 11:36 AM Thread Starter
My aftermatket amp suggests at least an 8-gauge wire for power so I would assume the power wire to the stock amp would not suffice. The also requires a 12v wire that "turns on" the amp when the radio turns on. The stock amp has the same wire but it's only 6V. So I think I will run a new 8 gauge wire and connect it to the headunit's "12V accessory" wire.
post #4 of 5 Old 06-25-2014, 04:51 PM
8 gauge wire is way overkill for a remote wire. Use 16-18 gauge wire for remote.
Fordzilla06 is offline
post #5 of 5 Old 06-26-2014, 06:13 AM
IronCobra's Avatar
Quoted: 9 Post(s)
I actually suggest sticking with the factory wire. The OEM amp is around 120watts and your aftermarket amp is probably around the same (Amps x Volts).
The OEM wire is going to be a higher quality copper than many aftermarket cheap cables and I believe it is 8 or 10awg.
Actually, before I put my foot in mouth, what AMP did you buy? model?
Its also cheaper and easier to simply wire in a SPST relay to your 6Vt lead to bump it up to 12vts for your amp remote lead. The relay go for about $2ea on amazon and about $5 at Radioshack.... and you only need 1
2016 F450 Platinum FX4 CC LWB
2016 Chaparral 360IBL Fifth Wheel: 15,500lbs
GONE - 2011 F250 FX4 6.7L Lariat Ultimate
IronCobra is offline
