No audio sound after startup sometimes...? - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 25 Old 04-12-2014, 04:16 PM Thread Starter
Anybody have an issue with their MyFord Touch acting up? A good 1 to 2 out of 5 times i will start my truck and there will be no sound even though the audio system is on. Doesn't matter if its on satellite, radio etc... I can turn the volume knob and it shows the volume going up and down but no sound. Then if I turn it off and then right back on it works fine.
Brand new 14 F350... its done it from the beginning.
happiicamper is offline
post #2 of 25 Old 04-12-2014, 04:55 PM
STX79's Avatar
Mine doesn't do that.
2014 F350 SRW Platinum, Ranch Hand bumpers, AMP Steps, BDS 2" leveling kit, Bilstein 5100 Shocks, 35x12.50R20 Toyo Mud Terrains.
STX79 is offline
post #3 of 25 Old 04-12-2014, 06:51 PM
Sterling6.7's Avatar
Quoted: 27 Post(s)
I had a similar issue with mine. Try disconnecting the batteries and turning the headlights on for about 10 minutes. This will reset a few things including the adaptive memory on the transmission. There is a single fuse that can be pulled that will just reset the MFT, but I never had the patience to track it down. Hope it works for you too!
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray, Lariat Ultimate, 3.55 ELD, Nav, etc.
Sterling6.7 is offline
post #4 of 25 Old 04-12-2014, 07:03 PM
Bjolls's Avatar
My new 14 does the same thing. I will try the fuse and see if that works.
2014 F350 Lariat FX4 - 22's on 35's - Recon Lights - AMP Steps - More on the way
Bjolls is offline
post #5 of 25 Old 04-13-2014, 06:39 AM
tmd
Welcome to the wonderful world of Sync
tmd is offline
post #6 of 25 Old 04-13-2014, 08:25 AM
mach14604's Avatar
The SYNC Module is bad. I just had mine redone last week. It needs a new one and then it needs to be reprogramed.
Want to Buy Ford Racing M-55 Exhaust
mach14604 is offline
post #7 of 25 Old 04-13-2014, 04:48 PM
Bjolls's Avatar
My 2011 with sync never had a problem. Maybe it is sync with My Ford Touch.
Bjolls is offline
post #8 of 25 Old 04-13-2014, 04:50 PM
Bjolls's Avatar
What is the sync module? My truck has less than 100 miles on it. I hope to not already be replacing parts
Bjolls is offline
post #9 of 25 Old 04-13-2014, 05:20 PM
mach14604's Avatar
I could not tell you. I know they ran a scan and the computer told the tech it was bad. After reprograming and new module installed. Knock on wood it has been working really well. Its under warranty so take it back. I have a 1000 miles on mine and I had to take it in but is started almost from day one.
post #10 of 25 Old 04-13-2014, 07:43 PM
Shugster2's Avatar
Quoted: 3 Post(s)
Yup! My brand new 2014 does the same thing! Aggravating!
2014 F-250 FX4 CCSB 4X4 6.7 Tuxedo Black
2" leveling kit (front only)
35x12.5x20 Toyo AT II's on stock wheels (had the nitto trail grappler MT's and only got 28K miles)
LED's on all interior bulbs
Rough Country LED fog's in place of stock
Ranch Hand bullnose with a 23 LED lightbar
Many more coming......
9-11-01........never forget!
Shugster2 is offline
