Ford Sync and Daylight Saving Time - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 1Likes
  • 1 Post By blwnsmoke
post #1 of 4 Old 04-05-2014, 05:48 PM Thread Starter
tcreek's Avatar
Now that DST is upon us, I needed to set the clock on my 2014 F350 Platimun. Told it to sync to the GPS time, and the clock was an hour off.
Searched thru all the settings, but could not see anywhere to tell it to use DST.
Doesn't Ford and Microsoft know about DST?
2014 F350 DRW Kodak Brown Platinum 6.7 PSD
2009 Mustang GT Convertible Candy Apple 4.6
2001 F250 Supercab Bright Amber V10
tcreek is offline
post #2 of 4 Old 04-05-2014, 08:43 PM
Quoted: 279 Post(s)
There used to be a "DST On/Off" option in MFT. I believe that was removed with v3.6.2. Even when it was there, you had to manually change it, so essentially you hit "off" when DST was over with and "on" when we changed the clocks again. It was confusing people because they were all saying the same thing as you, "it doesn't change the clock automatically".
So instead, with 3.6.2, they removed it and all we do is go to settings, clock and then hit the + or - once.
Yes you'd think with this technology that it would do it on it's own but apparently MFT is not capable of doing something that simple.
HeavyAssault likes this.
15 6.7 F350 CCSB 4x4 Platinum Bronze Fire
Husky mats, all LED interior, Nushield for MFT, Bakflip F1 with Bakbox 2, Dieselsite fuel filter, DeeZee tailgate assist, Hellwig Rear Sway bar, Bilstein 5100s
**Support the Online Vendors!!! Want your best price, buy from Scott Pratt!! Get your truck in 3-4 weeks, order to delivered!!
blwnsmoke is offline
post #3 of 4 Old 04-06-2014, 02:34 AM
Time change
Just touch the time display on your nav, settings should pop up.
Tautog is offline
post #4 of 4 Old 07-27-2015, 10:57 PM
somekevinguy's Avatar
Quoted: 35 Post(s)
Anybody else have anymore insight on this subject. This is totally screwed. I have to manually bump my clock ahead an hour in California during the summer but I drive out to Arizona a lot during the summer and when it changes time zones my clock advances an hour when it should stay the same. So I always forget and I'm cruising around AZ thinking it is an hour later. This is ridiculous!
2015 Ford F250 Lariat Ultimate Crew Cab Long Bed 4x4 6.7 - Carli Pintop 4.5" w/ Full Progressive Spring Pack - 18x9 5" BS Fuel Anza Wheels - 37" Toyo Open County M/T - Bakflip F1 - Amp Research steps with OBDII connection - Edge Insight CTS - Magnaflow Pro Series 4" Filter Back - Morimoto Mini D2S HID projectors - S&B Intake - 5 Star Tuning DPF on tune with SCT X4 - Pop & Lock electric tailgate lock
Thanks to
somekevinguy is offline
