Door keypad reprogram - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 4 Old 03-05-2014, 06:44 AM Thread Starter
ceking35's Avatar
Quoted: 5 Post(s)
Question guys, I traded the 2012 SRW for a 2014 DRW, when I was trying to reset the door code from the touch screen, it asked me to input the factory code, which I did. Then it asked Erase Code or Duplicate Code?, I thought I would need to erase it in order to input my new code. Well apparently I screwed that up because now I have erased the factory code that I need to set the new code!! Anyone else have this problem or am I the only dumb ars to do this? Please don't tell me I need to go back to the dealership????
ceking35 is offline
post #2 of 4 Old 03-05-2014, 07:14 AM
HighHP's Avatar
I accidentally erased mine but it still worked on the door for some reason. After a trip to the dealer to reflash after my remote start install it magically started working again and they werent even made aware of the issue, so yes sadly im pretty sure a trip to the dealer is in order.
2013 - F350 CCLB. - 40" Lift on 40s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #3 of 4 Old 03-05-2014, 07:49 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Same thing happened to me but I waited and sure enough, 24 hours later it worked again. No trip to the dealership for me. Your right, the option screen for this is confusing!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 4 Old 03-05-2014, 11:09 AM Thread Starter
ceking35's Avatar
Quoted: 5 Post(s)
Hmmmm.....it's not my DD so I will check when I get home. Man I hope that is it. I hate going to the stealership!!!
ceking35 is offline
