Lights - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 3 Old 01-27-2014, 05:06 PM Thread Starter
Lights
I am adding some LED lights inside and outside my truck. I installed some small LED under the dash, back side of the center console and a pair inside the center console. I have wired them to a double throw relay, with the normally open side wired a hot from the battery that the overhead dome lights closes when the lights are on and the normally closed side is hooked up to the upfitter switches so that I can turn the lights on while driving without the over head lights being on. Everything works great except I took power from the overhead dome light and it has the fade in and fade out thing going on and am afraid it is going to burn my relays out. you can hear them making noises when cutting on and off. Is there somewhere else I can get power from that doesn't fade?
VWs2 is offline
post #2 of 3 Old 01-27-2014, 05:51 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
You don't need a relay, just wire them to the upfitter switch normal. And for the dome light feature, just run the dome light wire through a diode then into the LED hot wire.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 3 Old 01-27-2014, 06:08 PM Thread Starter
True but I am gonna run more light then these and do not want to over load the factory circuit. I have another relay done the same way that is going to control bed lights and lights on the steps.
VWs2 is offline
