Where is the turn signal flasher location? - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 10 Old 01-17-2014, 12:54 PM Thread Starter
I will need to replace my OEM flasher with one that can support LED. Where is this thing located under the dash in my 2013 Lariat with center console?
2013 F350 Lariat CC SB Kodiak Brown
2007 F350 XLT CC SB 6.0 Dark Stone SOLD
2009 Heartland Razor 3612 Toyhauler
psdl6.0 is offline
post #2 of 10 Old 01-17-2014, 01:07 PM
You could just put resistors in.
Sent from AutoGuide.com App
2012 F250- 4.5in. lift, 24x12 rockstar II's painted tuxedo black, 37x13.50x24 M16's, KEM race tunes, 5in. exhaust, and much more.
DillonC is offline
post #3 of 10 Old 01-17-2014, 01:18 PM Thread Starter
Nice shoes DillonC.
Yes, I could just do resistors, but I would rather get it done once at the source and be done with it vs having 4 resistors dangling out there melting all the plastic it can get its hands on. Flasher is $20 at local NAPA or $14 on screwbay.
psdl6.0 is offline
post #4 of 10 Old 01-17-2014, 01:43 PM
Nice shoes DillonC.
Thanks. Yeah I just didn't know if it's as simple as changing a flasher on these new trucks.
DillonC is offline
post #5 of 10 Old 01-17-2014, 11:05 PM
HighHP's Avatar
It isnt, the flasher is all electronically controlled through a module now. Im not sure what ford uses but dodge is the canbus system. Ford probably uses the same one. That click you hear in your dash under your gauge cluster isnt a relay clicking like in the old days, its actually an electronic circuit board simulating the clicking through a little speaker. You can find the speaker and unplug it. Same speaker does your door chime as well Im pretty sure for when you leave your keys in the ignition.
2013 - F350 CCLB. - 40" Lift on 40s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #6 of 10 Old 01-18-2014, 04:01 AM
^^I thought I had heard something like that before.
DillonC is offline
post #7 of 10 Old 01-18-2014, 04:24 PM
TampaSteve's Avatar
Feedback Score: 3 reviews
With Ford IDS you can tell the BCM not to flash fast with personality settings.
2012 F-250 6.7 CCSB
Spartan war hammer, wicked wheel II, S&B intake, 4" flow pro w/dual mufflers, rigid dually's, IPad in dash, JL stealth box under rear seat, Hertz HSK 165 front and rear, JL 450/4, 500/1, line x, roll x tonneau, Titan Tank, and coming soon 6" lift, American force 22x11 Recon SS wrapped in 37's.
TampaSteve is offline
post #8 of 10 Old 01-19-2014, 04:02 PM Thread Starter
Are Ford dealers the only ones with the IDS? I will have to check in with my dealer and find out how much they want to charge me for that setting.
psdl6.0 is offline
post #9 of 10 Old 01-19-2014, 04:14 PM
HighHP's Avatar
Most dealers wont charge you anything if they arent busy, only takes a few minutes. Last time i had to deal with a dealer for something like this the service manager just told me to tip the mechanic so i threw him $40. I know autoenginuity gets you into some of the computers on the truck but im not sure exactly what you can change, worth looking into. Im sure someone has access to the ids programs but they wouldnt be easy to aquire.
HighHP is offline
post #10 of 10 Old 01-19-2014, 04:40 PM
TampaSteve's Avatar
Theses days the VCM2 is married to the PC it is setup on.
2012 F-250 6.7 CCSB
