My HID Retrofit Project - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 100 Old 12-26-2013, 08:25 PM Thread Starter
kirbybc12's Avatar
Okay guys, I'm never one to post up walk-throughs or threads about any of my modifications or projects but I've decided to do one for my HID retrofit. I went the route of LED bars on the front which has been more of a pain than it's worth. So after reading through Marshall's (mts678) guide I decided to take advantage of TRS's black Friday sale and bought the following parts for 25% off:
Ballasts: Morimoto 5Five (50w) D2S
Bulbs: Morimoto 5Five 5000K D2S
Halos: Morimoto XB LED (White)
Projectors: LHD (3" Lens)
Shrouds: Apollo
Wire Harness: Relay: H13
Marshall was able to get ahold of some spare headlight housing for me. I baked them open yesterday. The ideal temperature was about 235 degrees for 18-20 minutes. The tools you'll want are a 5mm socket (to remove the bolt in the corner), box cutter, 2 flat head screwdrivers (width of head doesn't matter too much), a putty knife, and a lot of patience.
I started the process by cutting the glue along the seam at the bottom of the housing, then took the putty knife to the grill side, slicing deep into the perm-seal glue. Don't dig too deeply into the side because you'll do what I did and slice through the plastic. Once you have this cutting done, you can start to pry the lights open. If the glue is not soft at this point, stick the lights back in the oven. Dig the screwdriver far back into the bottom section of the housing, make sure you have the tip behind the edge of the housing before you start to pry the lens off. Do not worry about bending the black flared piece above the lens, as long as your housing is still warm you won't have to worry about it snapping. Once you have the lens peeled back a bit, stick your second screwdriver next to it and continue the process in the direction of the grill side of the housing. I found this method to be the safest because that side is flat. I worry that if you go down the fender side the shape will become deformed and more difficult to reseal.
Here's a picture of the housing open
I ran into one issue with these particular housings. One of the plastics bolts that holds in the lower reflector, and is used for aiming was snapped:
I did some research and found this product called Q Bond online, it looks amazing and for $12 I think I can take the risk.
I'll try make some more progress tomorrow if I have the time. Half of the reason I made a thread is so that, hopefully, some of you guys give me the push to continue through the project.
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #2 of 100 Old 12-26-2013, 10:07 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
Subscribed!
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #3 of 100 Old 12-27-2013, 02:03 AM
tony97gt's Avatar
I think the hardest part of the retrofit is building up the courage to finally start the project. Good job, keep going and take your time to get it done right.
Question: Why not just find that broken part online and order it so you don't run the risk of having to open up the lights again later after all your hard work?
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #4 of 100 Old 12-27-2013, 07:30 AM Thread Starter
kirbybc12's Avatar
I tried looking on ford parts and it's either the full assembly or nothing lol. I ordered Q Bond, it was $13.99 with free shipping for 2 sets of the glue with the bonding powder. Hopefully I get it sometime next week. The big task for today is to disconnect the reflectors without breaking the other adjustment tabs off
2.5" Carli Commuter
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
post #5 of 100 Old 12-27-2013, 09:31 AM
Which Apollo shrouds did you get? I ordered the Apollo 3s and they are a lot bigger than I expected. They will fit in the bottom reflector but will have to be cut down top and bottom to fit in the turn signal reflector.
Sent from AutoGuide.com App
2012 F250- 4.5in. lift, 24x12 rockstar II's painted tuxedo black, 37x13.50x24 M16's, KEM race tunes, 5in. exhaust, and much more.
DillonC is offline
post #6 of 100 Old 12-27-2013, 09:36 AM
Thanks for the post. I'll be watching because I will be doing this in the near future.
Smitty44 is offline
post #7 of 100 Old 12-27-2013, 10:11 AM
mts678's Avatar
Quoted: 7 Post(s)
I think I used a smaller flathead to pop them off. You might have to buy a trashed headlight to get them parts, ford or anybody else don't sell parts of the headlights (not 100% sure but pretty sure) you could buy an 05 headlight for cheap they have the same ball stud type bolts in them
Marshall
mts678 is offline
post #8 of 100 Old 12-27-2013, 10:45 AM Thread Starter
kirbybc12's Avatar
I went with the standard Apollos, that seems to be the norm for these trucks. Although, I read through Tony's project and loved the look of the Panamera shrouds with the Halos. I'll see how these turn out and make a decision. Not looking forward to trimming the shrouds at all though.
I might end up doing that if this Q Bond doesn't work well. I think I can probably pick up a headlight set from that age for like $40. I have the backing in the oven right now, removing the rest of this glue from the channels. Any idea how these ball studs snap out? It looks to me like they have to be pushed down and then turned to slide out, but I can't be certain.
2.5" Carli Commuter
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
post #9 of 100 Old 12-27-2013, 04:59 PM
Keep it up, looking to do this with the new lamps. Haven't seen a DIY on the new models. You thinking dual projectors or single in each lamp?
jordan572 is offline
post #10 of 100 Old 12-27-2013, 05:01 PM
Have you started yet?
