Remote Starts and heat question - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 13 Old 11-25-2013, 03:41 PM Thread Starter
Is there a way to remote start truck and have heater come on and heated seat warm up...?? I cant figure it out...
2013 F350 CC KR SRW. Ruby Red/ Tan trim
Loaded!
SOLD
99 F250 EXt cab 7.3 Lariet. 170,00...no issues!
JMCFAN is offline
post #2 of 13 Old 11-25-2013, 05:03 PM
MorganM's Avatar
Quoted: 3 Post(s)
I don't believe these settings are adjustable...I've read they are factory pre-set. My heater does start if the outside temps are low enough, though the seat warmers don't turn on.
MorganM is offline
post #3 of 13 Old 11-26-2013, 02:54 PM
My truck when remote started does turn on the heated seats steering wheel and heat but when I turn the key on everything turns off even the heat
2013 platinum f350 cclb
2013 lariat f550
markssylver is offline
post #4 of 13 Old 11-26-2013, 10:56 PM
Mine does that too, was set from the factory.
Will preheat even above freezing.
2013 F-350 Platinum 6.7 4X4 CC LB
2007 F-150 XLT 5.4 4X4 SC SB
1999 F-250 XLT V-10 4X4 CC LB
XR250R is offline
post #5 of 13 Old 11-27-2013, 07:55 AM
Yeah you would think though it would leave the heat on whatever you had it on before you got out of it I know that's how GM s work
2013 lariat f550
post #6 of 13 Old 11-27-2013, 08:11 AM
Paul's Powerstroke's Avatar
Quoted: 2 Post(s)
If you have it on auto temp and you remote start it will adjust inside temprature to what you have 'My Temp' set to and the heat or cool option will turn on, but like markssylver said once you insert key it does shut it off and the heate or cooled seat isn't at full blast it's just seems like it's at a low setting, nonetheless you will feel it some especially if it's real cold. During the winter months I will keep the "my temp" at 76 so it warms up faster inside and I usually turn the temp down once the truck engine warms up more.
2016 F-350 6.7 Lariat Platinum DRW Shadow Black
2015 Puma Unleashed Palomino 351-THSS 37' 5'er Toyhauler
"Just put that hammer down and give it hell" - Jerry Reed.
Paul's Powerstroke is offline
post #7 of 13 Old 12-04-2013, 04:21 AM
Hoverp's Avatar
Does your steering wheel heat as well with my temp?
I just got my truck and am trying to figure this out. It's got the rapid aux heat in it also.
Where is the "my temp " in the settings? Or are you talking setting the temp manual to a degree number?
Thanks for the help!
2014 F350 CC Short bed, Fully loaded, Platinum Edition. 6.7L Scorpion Tuxedo Black. 3.55 ELD, FX4, Sup heater, 5th package , BFG Radial All Terrain: icon_ford:
Hoverp is offline
post #8 of 13 Old 12-04-2013, 06:26 AM
Quoted: 2 Post(s)
When you go to the climate control screen, you would see a soft key that will show a steering wheel. If you don't see that icon then you don't have a heated steering wheel. Mine doesn't have it.
The 'My Temp' is also on that screen. First set the cabin temperature you are comfortable in. My is set to 71 degrees. Then find that 'my temp' icon and hold it for a few seconds. It will hold the temperature settings and everytime you remote start your truck it will either warm up or cool down to that temperature based on the outside temperature.
post #9 of 13 Old 12-04-2013, 05:26 PM
Hoverp's Avatar
Copy all, thanks.
But do the heated seats come on, and the steering wheel heat( my truck does have that) but I don't know if the seats and the wheel will do that.
Thanks !
Patrick
Hoverp is offline
post #10 of 13 Old 12-04-2013, 09:08 PM
Hellobatman's Avatar
I've had my heater and heated seats come on in 40 deg weather here in texas. Awesome features even more for the few blustery mornings we do get. As stated, all goes off once truck is turned on though.
2013 F-250 Lariat FX4, 6.7 Scorpion, All the bells and whistles!
Hellobatman is offline
