Rigid on Aux 1 over thinking. - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 16 Old 11-21-2013, 08:45 PM Thread Starter
Ryan2012F350's Avatar
Garage
Need some advice gents. Been reading about hooking my rigid bar to aux 1 and I think a lot of people are over thinking it.
Can I not just chop that harness that came with it and run up fitter 1 power to pass through wire to red on rigid and black on rigid to ground?
I see people using the whole harness and crazy stuff.
Sent from AutoGuide.com App
2012 F350... Problems so far: Rear pinion seal, rad split, U-Joints, Waste gate tubing TSB.
4.5" Carli Lifted, 2.5" Kings, 37" Toyoed, Carli bagged, Wireless compressored, 5th hitched, rigids on both ends, slip tanked, titan tanked, upfittered, 12v pumped. Last truck I'll ever own.
Ryan2012F350 is offline
post #2 of 16 Old 11-21-2013, 11:39 PM
kirbybc12's Avatar
I know that the rigid also has a blue, which I assume is for the switch. As long as the light is grounded and getting a positive charge from the upfitter you should have no problems.
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #3 of 16 Old 11-22-2013, 12:00 AM Thread Starter
Garage
Yeah that's what I mean. I'm talking it the whole harness apart and just use the plug in from light to wires with just the red and black left. Red to up fitter. Black to ground.
post #4 of 16 Old 11-22-2013, 02:21 PM
I did that on my D2 for the fog light replacements, I just cut the wire at the back of the OEM fog light soldered that to the rigid light wires and plugged them up. Threw the whole rigid wire harness in my parts bin.....
Yamapro is offline
post #5 of 16 Old 11-22-2013, 02:31 PM
ZMANN's Avatar
Quoted: 1477 Post(s)
it's all about amps
you have the light bar specs just make sure the up fitter you choose is compatible
otherwise u use the relay
We Miss you Ronnie
ZMANN is offline
post #6 of 16 Old 11-22-2013, 04:57 PM Thread Starter
Garage
Thanks guys that's what I was thinking its way less than the 30 amps up fitter 1 is good for (I think it's 30) any way will hack off the excess and flange it up.
post #7 of 16 Old 11-28-2013, 05:43 PM Thread Starter
Garage
Well. It's as easy as it seems. Aux 1 yellow wire to pass through wire. Pass through wire to positive on light. Ground on light grounded and good to go. The rest of the harness is spare parts.
post #8 of 16 Old 11-28-2013, 05:45 PM Thread Starter
Garage
Rigid on Aux 1 over thinking.-imageuploadedbyautoguide1385689477.971181.jpgRigid on Aux 1 over thinking.-imageuploadedbyautoguide1385689506.934330.jpg
And it's crazy bright haha.
post #9 of 16 Old 11-29-2013, 08:13 PM
Cumminsgone's Avatar
Quoted: 9 Post(s)
Exactly how I wired mine, gotta love those upfitters, fused, relayed, yours looks good Ryan
[/URL
Cumminsgone is offline
The Following User Says Thank You to Cumminsgone For This Useful Post:
Ryan2012F350 (12-20-2013)
post #10 of 16 Old 12-18-2013, 01:10 PM
That's what I did with mine. I left the plug that's made to the light itself and just took what that plugs into and attached wires to it. That way if I need to take the light off I can just unplug it and unbolt it
2012 F250- 4.5in. lift, 24x12 rockstar II's painted tuxedo black, 37x13.50x24 M16's, KEM race tunes, 5in. exhaust, and much more.
DillonC is offline
