Backup Sensors - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 6 Old 11-21-2013, 10:07 AM Thread Starter
Backup Sensors
Anyone else have an issue with their backup sensors being overly sensitive? Mine beeps at me any time I put the truck in reverse. I've cleaned the sensors to verify there isn't trash setting them off but still have the same sensitivity. The dealer says it's normal but my 06 never beeped constant in reverse.
2012 F-350 Crew Cab Lariat 4X4
H&S XRT Pro; DPF deleted; S&B Air Intake
2006 F-350 Crew Cab XLT 4X4 *SOLD*
hmdavid is offline
post #2 of 6 Old 11-21-2013, 04:23 PM
Alberta Advantage's Avatar
Quoted: 19 Post(s)
Mine do it on my '09. It was actually a bad sensor that needed to be replaced. I now have two bad sensors and decided to say fu(k it as the sensors are expensive and seem to go out quite often. I was quoted $500 for parts and labor to install two new sensors in addition to the hour shop rate to diagnose the problem.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3 of 6 Old 11-21-2013, 04:47 PM
greygearhead's Avatar
Thumbs up
I had this issue last spring and it is NOT normal!!! My dealer could not duplicate the issue and the Ford tech line said to replace the PAM but it didn't fix the false beeping.
I luckily have some "friends" in upper management at the Kentucky Truck Plant and their answer was:
"99% of the time, a FALSE tone with nothing behind the unit is a SENSOR issue. 50% of the time, they are just dirty or ICE. Our sensors DO NOT LIKE ICE. The KEY thing here is to capture the truck exhibiting the concern and monitor the PIDS using the diagnostic tool (any Ford Dealer will have this). They will need to pull up the PIDS for the PAM module and monitor the rear sensors, the PID values are: LR_CNRD, LR_CTRD, RR_CNRD, RR_CTRD."
"A GOOD reading will read 100in with NOTHING behind the unit. But, if you can capture the beep while nothing is behind the unit, you will most likely see ONE of these values go anywhere from 0-40 in.
The sensor that is bad should be changed.
LR_CNRD – Left Rear Corner
LR_CTRD – Left Rear Center
RR_CNRD – Right Rear corner
RR_CTRD – Right Rear center
If you can’t repeat it, I would suggest all 4 sensors be replaced."
They sent 4 new tested sensors to my dealer FEDX overnite and the problem never came back .
2012 F350 2wd srw 8' Lariat 6.7
2004 Ranger FX4 Level II
2008 Mustang Bullitt dhg
greygearhead is offline
post #4 of 6 Old 11-25-2013, 10:18 AM Thread Starter
greygearhead,
Thanks for the info brother. I am taking the truck in today for a faulty tire pressure sensor and I will ask about this.
hmdavid is offline
post #5 of 6 Old 11-26-2013, 06:55 AM Thread Starter
So I had to basically force the dealer to test my backup sensors and they found the two inner sensors were bad. Replaced the sensors and now it works great.
hmdavid is offline
post #6 of 6 Old 11-26-2013, 07:52 AM
Thumbs up
Ah, the power of the internet. Knowledge is POWER! Glad they decided to see it your way!
