How to insall a factory backup camera and mirror - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 1Likes
  • 1 Post By sagebel
post #1 of 7 Old 09-24-2013, 03:36 PM Thread Starter
sagebel's Avatar
Quoted: 8 Post(s)
I did this a while ago on a different forum.
I used a 2008 tailgate with the camera in the handle and a 2008 rear view mirror. I found both at online salvage yards.
Camera wiring is as follows:
There are 5 wires that come out of the camera and go to a connector at the bottom of the tailgate (to allow removal of the tailgate).
Pin 1 White/Brown tracer: 12V power
Pin 2 White/Green tracer: NTSC(video) +
Pin 3 Purple NTSC(video) -
Pin 4 Black Shield(not used)
Pin 5 Black/White tracer: Ground
Since I used only 4 of the wires, I cut the factory connector off and bought a trailer wiring kit and used the flat 4 connectors at the bottom of the tailgate. (I just cut the Shield wire off.)
For the mirror, I wired it so that I can switch it on manually or have it come on when reverse is selected.
There could be anywhere from 5 to 9 wires coming out of the mirror depending on the vehicle you source it from. You will need to splice into the following wires that come out of the mirror:
Pin 1 White/Blue tracer: Constant 12V power
Pin 2 Green/Orange tracer: Switched 12V power (from reverse or selector switch)
Pin 3 Black: Ground
Pin 8 White/Green tracer NTSC(video)+
Pin 16 Light Brown/Purple tracer: NTSC(video)-
Other unused wires from the mirror:
Pins 4,5,6,7,12,13, and 14 not used
Pin 9 Yellow/Green tracer: Compass +
Pin 10 Blue/Gray tracer: Compass -
Pin 11 EOC+
Pin 15 EOC-
john galt likes this.
2012 F350 DRW King Ranch FX4
Originally Posted by nighthawk285 View Post
Pull it sideways back and forth....and don't be gentle
Originally Posted by Six0~Stroker View Post
I was just planning on running over here and whipping it out. Sent from
sagebel is offline
The Following User Says Thank You to sagebel For This Useful Post:
probuilder (03-25-2014)
post #2 of 7 Old 03-25-2014, 04:51 AM
probuilder's Avatar
Great write up thank you for the wiring info.
I am guessing here:
Pin 11 EOC+
Pin 15 EOC-
Are these for the automatic dimming rear view mirror? If so were do you run those wires to? Or are they just power and ground and the sensor is built into the mirror itself?
2011 F350 XLT, CC LB, 4x4, SRW, Powerstroke 6.7, Mini Maxx, Factory Remote Start added, Productivity screen added, All White.
probuilder is offline
post #3 of 7 Old 04-09-2014, 12:40 PM
I have a question about a new camera? I am putting a flat bed on my truck and it doesn't have a place for a camera, that I have in my tailgate. Any ideas?
williv is offline
post #4 of 7 Old 04-09-2014, 01:22 PM
john galt's Avatar
Quoted: 1088 Post(s)
mount it under the flat bed above the license plate?
behind the edge of the bed to keep it out of harms way
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #5 of 7 Old 04-09-2014, 04:53 PM Thread Starter
sagebel's Avatar
Quoted: 8 Post(s)
If you will be hitching up a 5th wheel or GN I would put it up on the headache rack. If not, somewhere out of the way where you can see to hook up a trailer.
sagebel is offline
post #6 of 7 Old 04-09-2014, 08:03 PM
What camera would anyone recommend?
williv is offline
post #7 of 7 Old 05-09-2014, 08:43 PM
Quoted: 333 Post(s)
Feedback Score: 5 reviews
Tagged.
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is online now
