Load Center - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 7 Old 08-08-2013, 11:54 PM Thread Starter
Load Center
I am in the process of adding marker lights between tube steps and pinch welds, raptor type lights in grill and air dam, light bar across rear. I was thinking a load center would be a great idea to keep from having to hack factory harnesses, and not using t-taps or fuse taps. My other thought was to run the feeds from the trailer harness as it has all the connections needed. Does anyone know where a person can find the materials needed to make this work? I've seen the wiring kits for street rods and feel they are quite a bit of overkill. Thanks for your input.
MsBhavn2 is offline
post #2 of 7 Old 08-09-2013, 12:07 AM
BIG Laing's Avatar
Member for a year and first post?
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 7 Old 08-09-2013, 12:10 AM Thread Starter
Lots of reading on here. Surely didn't want to ask a question that has been answered 1000 times.
MsBhavn2 is offline
post #4 of 7 Old 08-09-2013, 12:35 AM
BIG Laing's Avatar
I appreciate that. Someone will chime in the next 24 hours has a lot more knowledge then I do.
post #5 of 7 Old 08-27-2013, 04:36 AM
056oh's Avatar
Garage
Hers my plan haven't done it yet, waiting till i get fusion bumpers and do it all at once. my plan should be a fairly clean install and look almost factory. looking at taking the Ford Goose neck/ 5th wheel trailer wiring harness FOMOCO part # 13A576 2012 Ford F-350 Super Duty Trailer Towing Jumper Harness | FordParts.com , and cutting that harness and putting in junction box TRUCK LITE CO INC Junction Box Assy, Rnd Surface Mount, Grey - Electrical Boxes - 5LMP0|50400-3 - Grainger Industrial Supply mounted to the frame running all the accessory lights for the junction box. hope this helps you.
2012
F-350 Lariat X-Cab 6.7L Powerstroke 4x4 3.55 electric locking rear axle
2013
Taurus SHO 3.5L ECOBOOST
056oh is offline
post #6 of 7 Old 08-27-2013, 06:32 AM
Quoted: 2 Post(s)
For a simple fuse block, look at Blue Sea. They make marine power products. They have some small distribution blocks you could use to feed the various circuits, and relays, fuse holders etc. May not be exactly what you want but will probably get you some ideas
Hopeless Diamond is offline
post #7 of 7 Old 08-28-2013, 04:15 PM
Quoted: 6 Post(s)
You just made BIG Laing's decade! If everyone searched before asking he would be a happy man!
2016 Cadillac Escalade ESV
2014 Mercedes E350 Sport
2012 F350 6.7L CCLB Lariat Ultimate SOLD
2007 F350 6.0L CCLB XL FX4
2010 F350 6.4L CCLB DRW XLT SOLD
1970 FORD TORINO COBRA 429
fosterelli is offline
