Trailer Wiring - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 4 Old 07-01-2013, 08:41 PM Thread Starter
Trailer Wiring
Had a tough weekend on the trailer wiring, put the boat in the water without unplugging now I have all kinds of electrical problems in my trailer hookups.
I have a 2013 F350 6.7 so I'm not getting much help on manuals since they aren't out yet. The trailer tail lights work but backup and stops/right/left are all out. I've pulled every fuse and swapped relays that makes sense in the manual.....can't find the problem. Any one got some ideas? Anyone know of an inline fuse somewhere?
traviswy is offline
post #2 of 4 Old 07-01-2013, 09:01 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Check all the trailer bulbs, if water got into the light housings the bulbs are probably your problem.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 4 Old 07-02-2013, 11:12 AM
If you've got a multi meter and know how to use it, or even a very simple 12VDC test light, you can see if you have voltage at the trailer plug on your truck. You said the tail lights are working, so you can skip that step. Have someone step on the brake pedal and see if you have brake lights operating on the truck and then see if you have 12V at whichever pin is used for the stop lights, at the trailer plug. If there is voltage there (12VDC), then it's obvious that the trailer has the problem and not the truck.
xxrated is offline
post #4 of 4 Old 07-04-2013, 08:21 AM Thread Starter
Looks like we got it. The trailer has multiple grounding and it masked my problem. Thanks for the help.
traviswy is offline
