Seatbelt - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 4 Old 05-22-2013, 11:36 AM Thread Starter
Seatbelt
Is there a way to turn off the seatbelt chime without putting your radio on mute? I've read trough the manual and tried it on the first 2013 I had and it didn't work, now I have I a different 2013 I was wondering if there is a different way?
McChicken is offline
post #2 of 4 Old 05-22-2013, 01:17 PM
Look in the manual under seat belt reminder I believe. It's a unique process but it does work on a 13.
Andbiv is offline
post #3 of 4 Old 05-22-2013, 01:53 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
I just did this myself. Look in your owners manual and take your time with the procedure. Once you get it you will love not hearing that chime, I sure do.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 4 Old 05-22-2013, 05:21 PM Thread Starter
Are y'all talking about set your park brake and buckle and unbuckle the seatbelt? I've tried that on the first one and the chime quit but the radio still mutes itself if you don't buckle up. I want to be able to ride without a seatbelt and still listen to radio.
