Turn off RSS / Back up sensors - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 10 Old 05-16-2013, 05:34 PM Thread Starter
Yote223's Avatar
Has anyone figured out how to permnantly disable the, in cab, beeping from back up sensors. I know you can turn it off each time u place in reverse but that gets old. I have a hitch that stays on the truck and it automatically sets system off every time. I have a 2013 F350 with the OMC
Thanks in advance....
Yote223 is offline
post #2 of 10 Old 05-16-2013, 05:39 PM
BIG Laing's Avatar
I think you can turn it off completely in the settings... I will check mine tonight, hopefully someone chimes in before then.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 10 Old 05-16-2013, 07:23 PM
Would love to figure this out. I know if you unplug them you get a warning light.
Andbiv is offline
post #4 of 10 Old 05-16-2013, 11:27 PM
BIG Laing's Avatar
I was right. Settings > driver assist > back up assist > off = no beep beep beep.
post #5 of 10 Old 05-17-2013, 01:01 PM Thread Starter
Yote223's Avatar
I tried that but it will not last, if you cycle key switch u have to perform it again. I actually went out and programmed 1 of my keys with the back up assist turned off. The only thing that did was successfully kept it in enabled where I couldn't turn it off @ all. I must be missing something, I mean I have the equivalent of a 10k lb smart phone but I can't get this dang beeper to quite beeping..... What am I missing here...
Yote223 is offline
post #6 of 10 Old 05-17-2013, 04:42 PM
BIG Laing's Avatar
I just checked mine form last night, it is still off on my truck...
post #7 of 10 Old 05-17-2013, 05:18 PM
gabegoforth's Avatar
You should be able to turn them off, but you could just adjust them. I know you cold have them adjust away from your hitch.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #8 of 10 Old 05-17-2013, 05:59 PM Thread Starter
Yote223's Avatar
BIG Laing, thanks for double checking
Gabegoforth, gr8 idea
Looks like we will try a few things in the morning...
Yote223 is offline
post #9 of 10 Old 05-17-2013, 07:25 PM
Mine stay off when I do this.
For Sale: 2013 Lariat Ultimate CCSB 15K miles
3.55 ELD, Tinted, AMP setps, Retrax Pro, Two Spot Rigid D2 Dually's, Two Flood Rigid D2 Dually's, Fabtech 6in lift, Billstein struts, Dual Pro Comp Steering Stabilizers, 20in XD Addicts, 37x13.5x20 Toyo M/T, Line-X, Diversi-Tech 12" drop hitch, H&S Mini Maxx, 5in Flo Pro, H&S EGR delete, S&B CAI
FMKeith is offline
post #10 of 10 Old 05-20-2013, 03:09 PM Thread Starter
Yote223's Avatar
So still no luck.... Question for the people that have trucks where the beeper will remain off, do you have the rear camera and if so is it in the Ford emblem. Called two dealers today, one stated it could not be done, the other told me to bring in it and they would hook up a laptop and see if they could disable on the side....
Thanks
Yote223 is offline
