LED Conversion in Parking Lights? - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 17 Old 01-18-2013, 02:47 AM Thread Starter
Hey guys. New here. I own a F-350, and I switched to LED's. and they blink too fast. so someone suggested installing resistors. I bought those, now my question is: How do I install them?
4pcs Load Resistor Fix LED Bulb Fast Flash Turn Signal Blink Blinker 50W 6ohm | eBay
It shows here in the ebay ad how to. And I understand easily. Except... How do I know which wire is the turn, and which is the parking?
RMG-Inc is offline
post #2 of 17 Old 01-18-2013, 08:36 AM
barobbin's Avatar
Quoted: 3 Post(s)
which bulbs did you replace? front turn signals?
barobbin is offline
post #3 of 17 Old 01-18-2013, 11:50 PM Thread Starter
Both front and rears...
RMG-Inc is offline
post #4 of 17 Old 01-19-2013, 05:00 AM
Quoted: 57 Post(s)
Personally I would retun the resistors or not use them. There's a much easier fix. Buy an updated turn signal flasher that is rated for LEDs. It's a "plug ang play" solution. EP27L LED Bulb Electronic Flasher | LED Lights for Cars | 12v | Super Bright LEDs
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is online now
post #5 of 17 Old 01-19-2013, 06:05 AM
KAKnight's Avatar
Cutting and splicing can cause problems later on down the road.
Sent from my iPhone using AutoGuide.com App
KAKnight is offline
post #6 of 17 Old 01-21-2013, 07:20 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
May want to double check, I'm pretty sure the newer trucks, 08 and up, the computer controls flash rate and you can't just swap the relay out like the old trucks unfortunately. If someone figures this out, let me know. I'm trying to avoid splicing my self. I want led's but trying to avoid buying the cheap recon/eBay junk
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #7 of 17 Old 01-28-2013, 07:08 AM Thread Starter
oh shoot. Anyways, I bought the LED Flashers, but I cant figure out where they go... Anyone know?
RMG-Inc is offline
post #8 of 17 Old 01-28-2013, 07:22 AM Thread Starter
RMG-Inc is offline
post #9 of 17 Old 01-29-2013, 07:43 PM
2008+ vehicles have the the function of the turn signal flasher was incorporated into the software of the Smart Power Distribution Junction Box (SPDJB or SJB) or the BCM. The SJB / BCM is configured to provide lamp-outage (fast flash) indication on all F250/350/450/550. For proper function of LED lighting the SJB / BCM must be reconfigured to turn off the lamp-outage (fast flash) indication.
The following are the basic steps to turn off the lamp-outage (fast flash) configuration:
1. Ensure that the IDS is updated to the latest Database.
2. Select " Programmable Parameters" in the IDS Toolbox.
3. Select "Exterior Lighting".
4. Select "Stop and tail lamp outage configuration".
5. Select "Lamp outage turned off".
jasonmt is offline
post #10 of 17 Old 02-03-2013, 07:49 PM
travisH3's Avatar
Quoted: 2 Post(s)
You are the man. This needs to be stickied ASAP for the 08 plus truck. The computer controls that rapid flash so you can't just plug in a new relay. I will be calling my buddy and getting him to hook the IDS up to my 2010 and see what it does. Thanks
T-rav
2010 F350 6.4-
travisH3 is offline
