Wiring Issue - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 6 Old 08-11-2012, 03:30 AM Thread Starter
OneTon2011's Avatar
Quoted: 17 Post(s)
Wiring Issue
Got my 20in rigid industries led light bar n yesterday and got it installed. Im sure this question has been answered already n if so my bad. I couldnt get the light to work with the upliffer switch, im almost certain i didnt have a good ground. I ended up just using the supplied switch until i figure it out. Could someone give me some insite on connecting the wires - red, blue, n black(ground) to the upliffer switch (yellow wire) and what or where the ground was grounded? Oh n damn this ligbt is bright.
Shawn - 2011 Super Duty 6.7L Lariat
Oxford White / Sterling Grey two tone
12"-14" PMF 4-Link Long Arm Kit / Reid Racing High Steer / Crown Performance brake lines
King Shocks / SS M-16 40x14.50r22 / 22x12 AF
Yukon 4:30 / Monster Hooks
AMP Research / RIGID / RECON
PMF / Bushwhacker / AFE CAI
H&S Mini Maxx / H&S Delete / ARE
FLO-PRO / Road Armor
OneTon2011 is offline
post #2 of 6 Old 08-21-2012, 07:58 AM
Quoted: 3 Post(s)
For $699 it better be bright.
svtbolt2001 is offline
post #3 of 6 Old 09-04-2012, 09:11 AM Thread Starter
OneTon2011's Avatar
Quoted: 17 Post(s)
Actually I only paid $530 for light and bumper bracket. All is hooked up and looks awesome!
post #4 of 6 Old 09-04-2012, 09:53 AM
I ended up calling Rigid on this issue and the guy at Rigid told me to cut the provided wire just before the relay. I had the factory upfitter switches so the relays are already wired and did not need the relay. The only wire that I needed was the red and black wire. The red wire went to upfitter switch and the ground wire was grounded in the picture below. The ground is where other ground wires are attached and can be located on the drivers side right up against the firewall...... Hopefully the yellow arrow is visible in the picture. The blue wire that came with the wire harness is used to power the switch, per Rigid.
offroadsd is offline
post #5 of 6 Old 09-04-2012, 10:16 AM Thread Starter
OneTon2011's Avatar
Quoted: 17 Post(s)
offroadsd -
Yea i finally figured it out. Thanks for the heads up. I was going to use the area you have illistrated in the pic, but i just grounded to the battery. Thanks for the info though!
post #6 of 6 Old 09-04-2012, 11:18 AM
I just ordered two of the SRM mini flush mount ambers to install as well. I will post some pictures once I am done later this week. Hopefully they will look as good as I envision them, since there is no turning back once I make the cuts.
