High beams and fogs - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 15 Old 04-19-2012, 07:00 PM Thread Starter
High beams and fogs
Has anyone figured out how get the fog lights to stay on when the high beams are on? Fuses to jumper. Etc?
Current Rig: 2011 F-350 CCSB Lariat chrome FX4 Tuxedo Black.
Mods: aFe stage II, 8000k HID. 6" 4link Skyjacker Lift, 37" Toyos Wrapped around 20x9 XD MisFit Rims, H&S Minimaxx, 5" FloPro straight pipe
Traded: 2006 F-350 CCSB Amarillo Edition
Mods: 6" BDS 4-Link Lift Kit, 4" MBRP Cool Duals Exhaust, AFE Intake, Edge CTS Evo, 37x13.5x20 Toyo MT wrapped around XD Spy 20x9 Rims
UA Local 488 Steamfitter/Pipefitter
AlbertaStroker is offline
post #2 of 15 Old 04-19-2012, 08:09 PM
Term3's Avatar
Quoted: 2 Post(s)
I know this is possible as I've seen it on a forum lately. It was something really simple to do but I don't recall what though.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 15 Old 04-23-2012, 04:45 PM
joec410's Avatar
Quoted: 3 Post(s)
I just installed a Brite Box on mine. Innova Design & Distributing, Inc. - The Brite Box, Bulbzilla / Fogzilla, Diesel Turbo Lifesaver, Eclipse Sun Shade
2012 Ford F-250 Lariat, CC, LB, 4x4, 6.7 Powerstroke, 3.55 E-locker, Nav, Chrome BMF Novakanes 20"x9", 305/55-20 BFG AT's
joec410 is offline
post #4 of 15 Old 04-23-2012, 07:40 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
You can put your fogs on an isolated switch such as a rocker or an upfitter or just get brighter lights...
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #5 of 15 Old 04-23-2012, 10:58 PM
JSchuricht's Avatar
You should be able to do it for $10-15. What you will need is a 20-30a 12v relay, a fuse holder, 20a fuse and a bit of wire. The relay should have a normally open side and a normally closed side. Connect the NO to 12v by way of the fuse and the NC side to the wire going to the fog lights from the truck. Connect the common to the wire going to the fog lights, you cut it and put the relay in the middle. There will be two more connections on the relay, connect one to ground and the other to the 12v+ from the brights.
JSchuricht is offline
post #6 of 15 Old 04-24-2012, 06:50 AM
What part # did you order?
What was the price?
Are you happy with it?
Thanks,
Waxy
Waxy is offline
post #7 of 15 Old 04-24-2012, 05:34 PM
joec410's Avatar
Quoted: 3 Post(s)
I ordered the Fogster Kit. Just call them up and talk to them. The guy is very nice. I actually had mine from my 2008 and he told me I could reuse it as long as I switch two wires. He told me what to do and everything works great on my 2012. I think the price was about $90 and at is 5 years old and no problems.
joec410 is offline
post #8 of 15 Old 05-17-2012, 08:34 AM
Quoted: 5 Post(s)
Ordered my Brite box yesterday. $114 shipped. I will report on results.
svtbolt2001 is offline
post #9 of 15 Old 05-23-2012, 10:11 AM
Quoted: 5 Post(s)
Well I now have installed the kit and can say i am very impressed. Very easy to install and clean. I had some heartburn over spending $114 on something I could have cut and spliced into an uplifter switch but now that i have completed the install i have no regrets. Highly recommended if this is something that frustrates you about your truck.
post #10 of 15 Old 05-24-2012, 08:42 PM
Quoted: 6 Post(s)
Is there an FAQ set of directions for upfit switching the fogs?
Gray01 is offline
