Engine Block Heater temps? - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 11 Old 02-26-2012, 08:20 PM Thread Starter
rayray offroad's Avatar
Question Engine Block Heater temps?
hey guys i live in nj and have an 11 plug it in at night around 28-38 degree weather but when i get in the truck in the morning the temps for oil and coolant are only around 50-56 degree. now i used to have an 04 and temps in morning would be around 80-90 degrees is there something wrong with my heating element or are these new 6.7 not getting as hot as those 6.0. thanks guys and also please let me know what your temps are at?
2011 F350 4X4 cc king ranch
2004 f350 fx4 cc edge cts insight, stright piped.... SOLD!!!!!!!
running
rayray offroad is offline
post #2 of 11 Old 02-26-2012, 08:31 PM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
same here... when i have plugged mine in its usually around 60 degrees when i get in it in the morning according to my h&s....
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #3 of 11 Old 02-26-2012, 08:35 PM
Your block heater is only going to heat your engine up so much. Here in Alaska we add pan, battery and transmission pan heaters. I wouldn't even bother plugging in at the temps you are plugging in at. Your wasting electricity. The only reason to plug in in those temps would be if you are short tripping lot's and need to have heat in the cab a little faster. These engines do heat up surprisingly fast.
These newer strokes seem to be happier starting in subzero temps than previous models.
1998 Dodge 3500 Cab&Chassis, 12 valve, NV4500, 14' Flatbed
2011 Ford F-350 Lariat Crewcab, 6.7, automatic, 4x4 Traded in FERD on a Dodge!!! Back in the land of reliable diesels!
olypopper is offline
post #4 of 11 Old 02-27-2012, 04:34 PM Thread Starter
Hmmmm thank you
running
post #5 of 11 Old 02-28-2012, 11:39 AM
oly is correct, you don't need to plug in until it gets down to zero or something colder than you have now. The actual temps are in your owners manual for when you need to plug in. These newer diesels (all brands) are much better cold starters than in the past.
There is a certain advantage to having 50 degree oil at start-up though so I would not call it wasting electricity!!! You keep her warm and she will serve you well.
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
post #6 of 11 Old 02-28-2012, 10:27 PM
van-boy's Avatar
i have an 05 and i plug it in when temps get below freeing. starts at 3 and i unplug when i leave around 5 or 6. the heaters were good enough to keep frost of the front windows. im thinking ford went to a cheaper heater to cut down on the 18 cents per truck.
van-boy is offline
post #7 of 11 Old 02-28-2012, 10:35 PM
If it's oil temp/oil flow you are worried about then install an oil pan heater. Heating up with a block heater is only heating your coolant. Your oil is still cold in the pan until it has had a chance to cycle through the block and oil cooler and get warmth from the coolant there.
post #8 of 11 Old 02-28-2012, 11:11 PM
Smoke Eater
i do it simply cause its nice to have a warm truck to get into on cold mornings .... and when i get a call for the fd at 3am and its 10 degrees outside its nice to hit the remote start before i throw my clothes on and by the time im in my truck is nice and toasty
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
fdchief is offline
post #9 of 11 Old 12-19-2012, 09:29 PM
hood72's Avatar
Send a message via Yahoo to hood72
My truck did not come with a block heater. I was really suprised about that in my experience every Diesel car / truck has had a plug in. I did notice when I bought mine from the Ford dealership there is a 400W and a 1000wand the only way to tell ( I guess other than going to the dealership and getting a printout of how your truck is equipped) is to look on the part of the heating element that a wrench fits onto its in very small writing but I saw mine said 1000w
hood72 is offline
post #10 of 11 Old 12-20-2012, 08:24 PM
If its below 35 I plug my truck in. Figure it's easier on the engine to have warm fluids.
2012 f250 Ccsb Ultimate Lariat, Powerstroke FX4- Tuxedo Black, Bakflip F1
Lrdchaos is offline
