Seat Power Source - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 2 Old 02-26-2012, 04:21 PM Thread Starter
Castaway's Avatar
Seat Power Source
Hoping someone may be able to point me to which wire under seat is safest power point for my cb. I have it powered from upfitter switch now but have quite a bit of alternator noise, and would like to access from power seats to prevent having to leave key turned on. Radio is mounted on side of console.
I am concerned with air bags involved that a simple mistake could turn costly.
We enjoy all these fancies, but they do make things more interesting.
Thanks in Advance
2011 F450 6.7 Lariat Pro Hauler
Castaway is offline
post #2 of 2 Old 02-28-2012, 11:51 AM
Sorry for the late answer, I just found this.
My idea is to use one of the "thru firewall" wires and go straight to the fuse box or, even better, the battery. Ford has provided a small bundle of wires that dead-end on each side of the firewall just for things like this. You don't want to cut into the factory harness anyway and risk warranty issues down the road.
You can find the under hood end of the bundle just behind the fuse box and below the master cylinder area, The "inside" end of the wires are tied up above the brake pedal. Use an ohm meter to make sure you have found each end of the same wire and go!!!
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
