Stereo Build - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 43 Old 11-19-2011, 05:51 PM Thread Starter
Stereo Build
About to order all of my stereo equipment and get things started on Monday. Going fairly high end on everything. I want a good sharp crisp sound.
(Added prices for those of you asking in PM)
Mosconi AS200.4 Amplifier (retail $1,699 got it for $1,400)
Focal FC 165 KRX2 Front (retail $1,200 got them for $1,100)
Focal FC 165 KR2 Rear (retail $900 got them for $800)
Mosconi A100.2 (not sure retail on this one.. got it for $650)
JL Audio Stealth Box along with a JL 13.5" TW5 subwoofer (retail $850 and that's what I got it for)
Keeping the factory head unit, and will need to run a Audioson Bit Ten Processor. (got it for $495)
Half to factor in all the wiring, base controls, dynamat, and labor. Total bill was a touch over $7,000 all inclusive.
Pretty excited! I drive this truck on a daily basis, and figured this will be something I will use on a regular basis. I also figure, that if I ever get rid of this truck for a newer model, I should be able to transfer all of it over, so it helps justify the cost of this stuff.
Will take pics when I start seeing stuff
2011 F250 CC SB Lariate
2008 Corvette Z06 590 RWHP 529 RWTQ NA
1993 MR2 700+ RWHP (parting out)
2013 Volkswagen GLI
2015 Jeep Grand Cherokee Overland Diesel
JsnMR2 is offline
post #2 of 43 Old 11-20-2011, 09:58 PM
Good luck with the install! It looks like the speakers and everything you chose will sound really good. Is your factory head unit the one with navigation? I have been wanting to put a sub and door speakers while keeping the factory nav unit and didn't know if the sound would be. I guess I will be following your thread
RIDE3311 is offline
post #3 of 43 Old 11-20-2011, 11:02 PM Thread Starter
Yup factory head unit with Nav. The Audioson Bit Ten is what will allow things to sound proper while retaining the factory head unit. You will still need a separate amp or amps to power the speakers and sub though.
The JL Audio Steal box fits under the rear seat (you loose the storage bin) and looks very OEM. Same color as the interior and all.
I basically want this to be as OEM feeling/looking as possible while sounding amazing. Retaining all of the features of the OEM head unit and steering wheel controls is a must for me.
2013 Volkswagen GLI
JsnMR2 is offline
post #4 of 43 Old 11-21-2011, 06:27 AM
SynysterHD's Avatar
Subscribed! Can't wait to see it...
--Johnny--
'05 F250 Crew Cab, Lariat, FX4,
8" lift Fabtech 4 link
37" Toyo Open Country MT
'03 Turbo
Edge Insight CTS, SCT X3
ARP head studs
RCD EGR delete
STC fitting update
Dummy plugs/Standpipe update
blue spring mod
CCV mod
Zoodad mod
High Idle Mod
Cab light install
4" Turbo Back W/ 5" tip
Airaid
SynysterHD is offline
post #5 of 43 Old 11-21-2011, 12:27 PM
Blaque's Avatar
I want one of those subs badly. Dont really wanna lose my storage but I too want it to look as oem as possible. Good luck on the install.
Blaque is offline
post #6 of 43 Old 11-21-2011, 01:44 PM
tgaston's Avatar
I went with the SP2LK box w/ the JL Audio 13TW5-3 and love it! Fits and sounds great.
I had a down firing JL box a couple trucks ago and that sounded ok. This was also before the 13TW5 was available.
I would definitively recommend DynoMat for the rear wall and doors. Really helps quite things up.
ID:	30837   Click image for larger version
ID:	30838   Click image for larger version
2012 F250 6.7 -- Ready Lift 2.5 -- Recon -- 20" Mamba -- 35x12.5 Nitto Trails -- JL Audio C5-570's --JL Audio 13TW5-3 -- JL Audio 900/5 -- DynaMat -- JVC -- BOYO -- Retro Solutions -- Top Gun Customz -- And the list continues...... [/B]
tgaston is offline
post #7 of 43 Old 11-21-2011, 03:10 PM
SynysterHD's Avatar
how much did you pay for that box and sub?
--Johnny--
'03 Turbo
ARP head studs
RCD EGR delete
STC fitting update
blue spring mod
CCV mod
Zoodad mod
High Idle Mod
Cab light install
Airaid
post #8 of 43 Old 11-21-2011, 04:09 PM
F350SD's Avatar
subscribed
look forward to seeing the pics.
2015 F450 Platinum (me happy)
Montana 3625RE 5th wheel (wife happy)
USMC 89-93 / Wounded Warrior Project supporter
F350SD is offline
post #9 of 43 Old 11-21-2011, 04:58 PM Thread Starter
Everything's ordered. Install will happen Friday, Saturday, or at the latest, next Monday. Depends when parts come in. Thanks giving is slowing us down a bit.
Def have dynamat on the list
2013 Volkswagen GLI
JsnMR2 is offline
post #10 of 43 Old 11-22-2011, 09:05 AM
tgaston's Avatar
$360 shipped for the sub from Sonic Electronics
JL Audio 13TW5-3 (13TW53)13.5" Single 3 ohm TW5 Thin-Line Sub
$225 shipped for the box from SPL2K
2008superduty
tgaston is offline
