Fog Light Mod - Separate on/off via upfitter - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 1Likes
post #1 of 12 Old 10-06-2011, 09:13 AM Thread Starter
In an effort to have more light output when driving on rural roads, I made it possible to have my FOG lights on, even when my high beams are on.
For some reason, most manufactures make it so that when you turn your high beams on, your fog lights go off. This reduces the amount of light closer to the vehicle and sides of the road.
I connected the output wire from UpFitter #1 to one of the passthru wires. I then ran a wire from the passthru wire down to my fog light harness under the truck. I soldered in two diodes. One diode keeps the power from the upfitter going back to the BCM and thereby possibly confusing it. The second diode, keeps power from the BCM going back to the upfitter. I dont believe this one was needed, but since I had a pack of 25 diodes, I put it in.
The end result is beautiful.
1) I can have my fog lights on with no parking lights
2) I can have my fog lights on with my high beams
3) I can still leave it all auto and have my fog lights come on/off as it was from the factory.
Here are some pictures of the wiring. You will splice your power feed into the brown/yellow stripped wire after the harness.
Peel back the tape and loom to expose the two wires. Black is ground. You want the striped wire.
Cut the wire and cut about a 1/2 piece out to make room for the diode and solder it in. Be sure to orient it the correct direction.
Next tape over the end closest to the connector, so that when you solder the feed diode in, you dont cause the annode sides to touch and bypass the purpose of the diodes.
Then solder in your feed wire with its own diode on it.
All done. Tape it up, put the loom back and cable tie all wires.
AndrewF is offline
post #2 of 12 Old 10-06-2011, 09:14 AM Thread Starter
Here are some sample photos. Unfortunately, the iphone camera doesnt really show the difference as much as the human eye can tell.
First photo is high beams only.
This photo is highs, with the fogs on.
Can definitely see more light down load on the gravel, as well as on the sides, the bushes by the fuel tank, and the lower part of the bush to the left.
It was late, so I didn't take it for a drive in the dark to test it.
Total cost of the mod:
Time: 60 minutes
Diodes: $3
Split Loon: $2
Wire: (already had)
AndrewF is offline
post #3 of 12 Old 10-07-2011, 11:27 AM
F350SD's Avatar
that's a cool idea. my innate fear of screwing something up that can't easily be fixed usually kicks in when I read stuff like this but, with your write-up and photos, I might just have to try it. good post.
2015 F450 Platinum (me happy)
Montana 3625RE 5th wheel (wife happy)
USMC 89-93 / Wounded Warrior Project supporter
F350SD is offline
post #4 of 12 Old 10-25-2011, 03:16 PM
J-MAN's Avatar
Quoted: 2 Post(s)
could you give a part number on the diodes you used. I got some from radio shack and they suck! LOL.
The NEW rig 2016 F350 Lariat Ultimate CC/SB FX4
The past rigs:
2015 250 Platinum CC/SB
2011 250 Lariat CC/SB FX4
2006 250 XLT CC/SB FX4
2004 250 XLT sport CC/SB 2WD
J-MAN is offline
post #5 of 12 Old 10-26-2011, 07:40 PM
matty21's Avatar
very intuitive. i must say .this will be something i will look into shortly . very nice detailed writeup. and good clean install. kudo's.
on my last two harley trucks i had extra 6" lights : behind the grill in my 06 an on my bull bar on my 08 but never liked the look of them this is great
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #6 of 12 Old 11-01-2011, 09:43 AM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
This is a great idea!
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #7 of 12 Old 10-24-2013, 06:26 AM
DSL_PWR's Avatar
Quoted: 9 Post(s)
Great idea. Thanks.
DSL_PWR is offline
post #8 of 12 Old 10-27-2013, 06:27 AM
ATCguy's Avatar
Originally Posted by AndrewF View Post
...For some reason, most manufactures make it so that when you turn your high beams on, your fog lights go off...
"For some reason" = because it's illegal.
DOT regs state that a vehicle may only have 4 forward-projecting lights operating at a time (it's worded differently in legalese... but you get the idea).
2 Low beam + 2 high beam = 4
This is why most aftermarket PIAA or KC auxiliary lighting is labeled 'for off-road use only'.
Now, that said... I highly doubt any officer is going to pull anybody over for doing this. Simply having the fog lights on is not annoying or distracting to other drivers... such as having bright, highly-aimed, off-road lights on in addition to regular headlights.
A few years ago, it used to be much simpler to have your fog lights remain operating with the high beams on Ford trucks. You simply removed the fog light relay from the box under the hood... broke off the blade that connected the relay to the high-beam trigger... and reinstalled the relay back into the box. It took all of 15 seconds to do, and you didn't need to cut any wires, or solder in diodes.
I haven't researched if you can still do it with these newer trucks... but I don't see why not.
H&E likes this.
Tom
2014 F-450 PLATINUM
2014 Dutchmen Voltage 3200 5th Wheel Toy Hauler
2007 Honda GL1800A Gold Wing
ATCguy is offline
post #9 of 12 Old 11-10-2013, 10:16 AM
Quoted: 11 Post(s)
Somebody try this ^^ and report back to us!
2016 Cadillac Escalade ESV
2014 Mercedes E350 Sport
2012 F350 6.7L CCLB Lariat Ultimate SOLD
2007 F350 6.0L CCLB XL FX4
2010 F350 6.4L CCLB DRW XLT SOLD
1970 FORD TORINO COBRA 429
fosterelli is offline
post #10 of 12 Old 02-23-2016, 10:39 AM
Zejokee's Avatar
Quoted: 5 Post(s)
Years ago, and probably still is the law, here locally if you had offroad lights or additional fog lights, you had to leave covers on them while on the road. They could not be used on the road and must be covered up. I see tons driving around with light bars and KC lights but with out covers. So law must of changed or it is not enforced.
2011 F-250 SD Crew Cab FX4 Lariat 6.7 PSD SRW, H&S Mini Maxx, DPF delete, EGR delete, 5'' straight piped. Leveled.
04 F-350 SD Crew Cab FX4 Lariat 6.0 PSD SRW Stolen
Zejokee is offline
